Spark Plug & Injector Prices
Maik
Post22-12-2002, 17:23    Subject: Spark Plug & Injector Prices Quote
Hello, I'm currently looking for new fuel injectors and glow plugs for my Golf. When I inquired at an accessory store, I almost had a heart attack. Glow plugs are about €160 and fuel injectors are about €450 icon_eek.gif. Are these standard prices, or is the store overpriced? I don't have much experience with this because I usually only work on my own car, and until now (180,000 km), it hasn't needed any major replacement parts. I also saw glow plugs for €38 on eBay.
Are they also input/output (IO)?
Maik.
Translated on 22-08-2026, 19:46.
joergs
Post22-12-2002, 17:38    Subject: Spark Plug & Injector Prices Quote
@maik
It's indeed quite expensive! I recently installed new Bosch AT injectors in my 1Z, and they cost around €360 or €380. I think you can get the glow plugs from dieselsend.de for around €40 per set! Otherwise, at 'teileschieber,' the glow plugs are around €50-€60.
Translated on 22-08-2026, 19:48.
roter_Korsar
Post22-12-2002, 19:39    Subject: Spark Plugs eBay: Buy & Sell Online Quote
Hey Maik,
I also bought those candles. I contacted him because he was offering sets of 4 on eBay, but I needed 5. He then sold them to me directly, without using eBay, but at the same price as listed on eBay.
I then paid €50.13 including shipping. A Bosch service center in Bielefeld wanted €98 for the five spark plugs.
Best regards from Bielefeld.
Peter.
Translated on 22-08-2026, 19:49.
D.
Post22-12-2002, 19:47    Subject: Spark Plug & Injector Prices Quote
Hello Maik!
I had the glow plugs replaced at a VAG dealership earlier this year for my VW Golf (1Z).
He charged €120 for it (including VAT and labor costs), so that's acceptable.
Best regards, D.
Translated on 22-08-2026, 19:50.
Felixa6
Post27-12-2002, 1:56    Subject: Spark Plug & Injector Prices Quote
I somehow can't understand why one should replace all the ??glow plugs at once - after all, they are not wear items - especially not in a TDI!
You can first measure the current draw, locate the faulty glow plug, and then just replace that one – it's much cheaper that way.
Furthermore, these should be tightened with the correct torque; otherwise, they will likely come loose again (resulting in a gap).
On my (former) Golf, one spark plug lasted 30,000 km, the others lasted 180,000 km, and I still didn't have any starting problems.
Alex.
Translated on 22-08-2026, 19:51.
Gremlin
Post27-12-2002, 18:30    Subject: Spark Plug & Injector Prices Quote
Well...
When I read the mileage displayed on D.'s car's instrument cluster, it shows 212,000 kilometers (approximately 132,000 miles).
'In that case, I would replace all four spark plugs at once, so I only have to deal with it once and not four times a year...'
For my ALH, that might still work, but when I look at the older TDs icon_wink.gif,
But those things are really expensive.
CU Gremlin.
Translated on 22-08-2026, 19:53.
D.
Post28-12-2002, 17:32    Subject: Spark Plug & Injector Prices Quote
Hi Gremlin!
I had the glow plugs replaced because of starting problems. However, it turned out that they weren't the problem after all; it was the temperature sensor.
The spark plugs might have lasted a little longer.
I believe 'DocSnydor' had a mileage of 260,000 kilometers.
But the fuel injectors in my car are still the original ones!
Best regards, D.
Translated on 22-08-2026, 19:54.
DocSnydor
Post30-12-2002, 9:15    Subject: Spark Plug & Injector Prices Quote
@D.
No, you. I've only got 215,000 km on it right now. It must have been someone else. I don't want to have to replace the belt again in just 10,000 km icon_wink.gif.
But I still have the first candles and nozzles in place (nozzles = still!).
Translated on 22-08-2026, 19:55.
D.
Post30-12-2002, 22:04    Subject: Spark Plug & Injector Prices Quote
@DocSnydor!
Sorry!
Translated on 22-08-2026, 19:56.
No new posts Spark plug firing order Technical Data
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Preise für Einspritzdüsen (AFN) Diesel Engine Technology
No new posts Fuel Injectors: Different Prices with Needle Lift Control? Diesel Engine Technology
No new posts Timing Belt Replacement Cost Hamburg Diesel Engine Technology
No new posts VW Marine Engine Prices Upload
