VAG-COM: 1Z Diagnostics & Software (Solution)
huby
Post18-12-2002, 22:13    Subject: VAG-COM: 1Z Diagnostics & Software Quote
I know the problem.
Windows 98 must be installed, and the initial baud rate must be set to 240.
to be set. Best regards from huby.
Translated on 07-09-2026, 18:30.
Maik
Post19-12-2002, 7:59    Subject: VAG-COM: 1Z Diagnostics & Software Quote
What problem?
Maik.
huby
Post19-12-2002, 10:16    Subject: VAG-COM: 1Z Diagnostics & Software Quote
Hello Maik.
'Are you familiar with the problem (where the baud rate cannot be synchronized)?'
older control units?
Translated on 07-09-2026, 18:31.
Gremlin
Post19-12-2002, 23:31    Subject: VAG-COM: 1Z Diagnostics & Software Quote
No... I don't know it.
Toshiba Tecra 540CDT running Windows 98 SE.
The oldest car I've owned was a 1992 Golf, and the newest was my 2002 Octavia. In between, I've owned pretty much anything with a VAG engine.
No problems at all, not even with the adapter that is compatible with the original Jeffs interface (except for the optocouplers and transistors).
CU Gremlin.
Translated on 07-09-2026, 18:32.
huby
Post20-12-2002, 9:23    Subject: VAG-COM: Diagnose und 1Z-Fahrzeuge Quote
It's possible that the issue is with the adapter (from orig.Auto-Intern GMBH).
It is also stated in the manual that there are known issues with control units manufactured in the years 1993-1994.
'when it comes to the TDI.'
Soon, there will be an adapter that can read all baud rates!
Translated on 07-09-2026, 18:33.
Ratings - VAG-COM: 1Z Diagnostics & Software
