Golf Shakes: Causes and Solutions
Saskia.E
Post06-01-2009, 11:22    Subject: Golf Shakes: Causes and Solutions Quote
I'm having a problem with my Volkswagen Golf Mk3, manufactured in 1994, which now has an impressive 290,000 km on the odometer. A new engine was installed when it had 100,000 km.
It's always been like this: it jerks when you drive at low RPMs. But recently, it takes longer for the jerking to stop. So now it sometimes happens even at an engine speed of 2000 RPM, whereas before it used to happen around 1600 RPM.
I hope you understand what I mean and can help me figure out what the problem is.
I would be very happy about that.
You're welcome!
Translated on 06-08-2026, 17:45.
alsch
Post06-01-2009, 12:05    Subject: Golf Shakes: Causes and Solutions Quote
Hi.
So, you can find a lot of things on the internet, but not necessarily things like, for example, which engine is installed in your Golf icon_biggrin.gif.
Therefore, please provide more details about the golf club, otherwise it will just be guesswork, which would be useless.
alsch
Ford Focus Kombi
1,8er Benziner Bj 2000
0,0 Probleme, geht immer
Translated on 06-08-2026, 17:46.
Saskia.E
Post07-01-2009, 10:41    Subject: Golf Shakes: Causes and Solutions Quote
It's a 1.9 TDI engine.
Do you need any other information that might be helpful?
Translated on 06-08-2026, 17:47.
alsch
Post09-01-2009, 20:50    Subject: Golf Shakes: Causes and Solutions Quote
Don't be offended, but the 1.9 TDI still comes in countless versions, each identified with so-called engine code letters. This letter is located on the sticker at the very front of the service booklet, on the timing belt cover in the engine compartment, or in the trunk near the spare tire, also on a sticker. You take this (the engine code letter) and try searching here in the forum using "engine code letters and misfiring." Then there's a lot to read icon_cool.gif.
alsch
Ford Focus Kombi
Translated on 06-08-2026, 17:48.
R32 Turbo
2003 Volkswagen Golf
Post09-01-2009, 22:13    Subject: Golf Shakes: Causes and Solutions Quote
Crankshaft pulley is vibrating!!!
Check injection start!
Fuel injection pumps are often a source of problems with these vehicles.
Greetings.
Jasmin.
===The luxembourgish tuningcrew===
Translated on 06-08-2026, 17:49.
servusssss
Post09-01-2009, 23:55    Subject: Golf Shakes: Causes and Solutions Quote
@ Saskia.E, please review the article.
Without the engine code letters, it's like searching for something in the fog.
Translated on 06-08-2026, 17:50.
Post10-01-2009, 0:01    Subject: Golf Shaking/Vibration: Common Causes & Fixes Quote
Saskia.E wrote:
I'm having a problem with my Volkswagen Golf Mk3, manufactured in 1994.
servusssss wrote:
Without the engine code letters, it's like searching in the dark.
Also in 94 gab es nur einen TDI Motor im G3 ... That was the first set.
Search function: "1Z jerking" or "1Z stuttering".
The results already provide everything important for reading over the next two days icon_wink.gif.
Translated on 06-08-2026, 17:51.
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Causes of the shaking, Engine is shaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 99 AFN rußt zunehmend -Keine verbesserung mit mehr Laded... Diesel Engine Technology
No new posts Golf 4 TDI jerks/shudders Diesel Engine Technology
No new posts Golf V BKC engine shakes/vibrates until approximately 60°C Diesel Engine Technology
No new posts Help - Golf Plus 105 hp TDI is shaking/jerking Diesel Engine Technology
