Bus Transceiver SI9243EY
edazer
Post30-12-2002, 22:29    Subject: Bus Transceiver SI9243EY Quote
I have an adapter with a built-in SI9241 (K-line only) module.
This also exists for K+L, and is then called SI9243EY.
My adapter doesn't work with VAG-COM but with the old one.
VW-TOOL (now probably called VDS or something like that).
I think it's due to the strange adapter query that's built into the program.
Just a thought, you know? The plug works, so it doesn't matter.
approximately 3 years, and as far as I can remember, with all STG.
How much does a high-speed train ticket cost? I don't know.
ähh, where can I find the datasheet?
http://www.vishay.com/document/70017/70017.pdf
Greetings
edz
AndyO
Post30-12-2002, 22:40    Subject: Setup Time: 9.6us Quote
When measuring the delay time, values of 9.6us (increasing and decreasing) appear. With my acceleration capacitors, I achieve a value of approximately 5us (80% of the value) using Ulf's adapter. That would then fall into the 'green' category.
The point is that the SW VAG-COM is regularly updated and freely available. I hardly think anyone would give up on that.
edazer
Post01-01-2003, 19:49    Subject: Bus Transceiver SI9243EY Quote
Addendum:
Adapter works with Vag-com! Adapter status 0 found and ready
However, this is probably not the case for vehicles with L-line.
Consists of a MAX232, Si9241, 1 Transistor, and a pair of resistors.
and ELkos.
hello
edz
Rudi
Post02-01-2003, 11:36    Subject: Bus Transceiver SI9243EY Quote
Thank you very much for the information.
If you could provide a picture of your (obviously purchased) adapter, and/or even demonstrate the functionality of the device, that would be great.
The Si9243EY is, in fact, not better suited for diagnostic interfaces than the Si9241, as the L-Line connector is only an input (as with the Motorola MC33199). For an adapter, it might be necessary to use two drivers.
Best regards, Rudi
No new posts CAN Transceiver bei ASV MSG On-Board Diagnostics (OBD)
