Doku Polo MJ 2002, No Power Steering (Solution)
Michael II
Post30-12-2002, 16:08    Subject: Doku Polo MJ 2002, No Power Steering Quote
Polo MJ 2002 - No power steering due to water ingress.
Affected vehicle identification numbers (VINs):
WVWZZZ9NZ2Y000000 - WVWZZZ9NZ2Y053100
Cause.
1. Plugs that are not fully inserted.
2. Water ingress due to a dislodged seal on the connector block and central connector for power supply at the pump unit.
3. Capillary action of the mass flow towards the longitudinal beam.
Solution:
1. Check if all plugs are fully inserted.
2. Spare part.
Starting from cable end number 9N2 Y 041 990, the main cable is sealed.
In vehicles manufactured before a certain production number, the grounding cables may be severely corroded.
that they need to be replaced.
The leaky cable must be sealed with sealant.
to be sealed from tube No. D 176 404 A2.
Tschüss
Michael II
Translated on 14-07-2026, 15:31.
Ratings - Doku Polo MJ 2002, No Power Steering
No new posts Polo 9N: Power Steering Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2002, Gearbox noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo MK4 AC Noise: Diagnosis & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM: No Central Locking on Polo 1.4 TDI (2002) On-Board Diagnostics (OBD)
No new posts No MWB? Find MWB-free options now! On-Board Diagnostics (OBD)
No new posts 776 No communication Diesel Engine Technology
No new posts No Speed Limit: Freedom and Performance Diesel Engine Technology
