Golf V TDI 2.0 PD: Engine Stalling Issues
Bjoern
Post26-02-2008, 20:05    Subject: Golf V TDI 2.0 PD: Engine Stalling Issues Quote
Hi everyone, I'm signed up for the first time today and I'm already running into a problem:
My Golf V 2.0 TDI 140 hp, manufactured in 2004 and without a particulate filter, has a peculiar issue.
"At a coolant temperature between 50 and 70 degrees Celsius, the engine exhibits irregular idle fluctuations and then simply stalls. It restarts without any problems, and when the temperature exceeds approximately 70 degrees Celsius, the problem disappears."
The strange thing is that the diagnostic system doesn't show any error codes related to the "friendly!" device.
I hope someone can help me, as I couldn't find anything using the search function.
Thank you in advance.
Best regards, Björn from Lübeck.
Schnell und Sparsam TDI 2.0 Golf V
Translated on 29-10-2026, 19:50.
Karma: +807 / -0   Thank you, like it!
Post29-02-2008, 11:26    Subject: Golf V TDI 2.0 PD: Engine Stalling Issues Quote
As discussed via private message:
- Check the coolant temperature sensor.
- Check the power supply to the motor control unit.
- Check icon_smile.gif to see if the dataset from the STG is up-to-date.
Translated on 29-10-2026, 19:51.
mserge
Post13-03-2008, 15:27    Subject: Golf V TDI 2.0 PD: Engine Stalling Issues Quote
I had that issue with a Ford Focus once. It was the camshaft sensor. I'm not sure if VW has the same part.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 29-10-2026, 19:52.
No new posts VW Passat: ESP Light On - What to Do? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts A3 TDI: Engine Stalling - Common Problem? On-Board Diagnostics (OBD)
No new posts TDI Engine Failure: Common Causes & Fixes Diesel Engine Technology
No new posts Golf 3 TDI, 1994, keeps stalling Diesel Engine Technology
No new posts PIN Compatible? Easy Replacement - Is it Possible? On-Board Diagnostics (OBD)
