ABS Coding: Explained & How It Works
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
W8 Power
Karma: +0 / -4   Thank you, like it!
Post08-04-2008, 19:33    Subject: ABS Coding: Explained & How It Works Quote
Hello forum.
"Today, I read out some error codes on my Passat W8 and messed around a bit, but I don't know where or what I did. Now, the coding for the ABS and all-wheel drive is gone. It shows a coding of 00000. When I try to enter the old code, nothing happens... I'm also not sure what I need to do to fix it. How do I get the login back? I would be very grateful for any help. I've attached a scan. Now, the ABS light, the ESP light, and the handbrake light are all on and the handbrake is also beeping. I'm completely lost..."
Please help.
Saturday, March 22, 2008, 2:30:09:46308 PM.
VAG-COM Version: RKS 704.1
Data as of: 20070614.
Vehicle type: 3B - VW Passat B5.
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Vehicle Identification Number (VIN): WVWZZZ3BZ2E370981
Mileage: 129,800 km / 80,653 miles
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine. Label file: None.
Part number: 07D 906 018 C.
Part number: B5S-4.0L-AG G 4658
Encoding: 00173
Workshop #: WSC 43524
WVWZZZ3BZ2E370981 VWZ7Z0A4567481
"One error found:"
17755 - Bank 2; Camshaft position sensor (G163) / Crankshaft position sensor (G28): Incorrect assignment.
P1347 - 35-00 - -
Readiness: 0110 1001
Address 02: Transmission. Label file: RKS\01V-927-156.LBL
Part number: 3B0 927 156 AG
Component: AG5 01V 4.0lWR8 RdW 1821
Encoding: 01101
No errors found.
Address 03: Brakes/ABS
Label file: RKS\4B0-614-517.LBL
Part number: 4B0 614 517 E
Part: ABS/ESP all-wheel drive 1728.
Encoding: 05397
Workshop #: WSC 05311
"One error found:"
01119 - Signal for pedestrian detection.
35-10 - - - Sporadically
Address: 08, Heater/Climate. Label file: RKS\3Bx-907-044.LBL.
Part number: 3B7 907 044.
Part: CLIMATRONIC B5W8 0005
Encoding: 27010
4 errors found:
00603 - Actuator motor for footwell/defrost flap (V85)
37-10 - defective - intermittent.
01271 - Temperature control flap actuator (V68)
01272 - Actuator motor for central locking (V70).
01341 - Control unit in the instrument panel carrier, Comfort CAN (J285).
27-10 - implausible signal - sporadic.
Address 15: Airbag Label file: RKS\6Q0-909-605-VW5.LBL
Part number: 1C0 909 605 C
Part number: 0B AIRBAG VW61 04 0001
Encoding: 12354
No errors found.
Address 16: Steering wheel label file: RKS\1J0-907-487-A.LBL
Part number: 1J0 907 487 B
Component: Steering wheel electronics 0002.
Encoding: 00008
Workshop #: WSC 05314
No errors found.
Address 17: Combination instrument
Label file: RKS\3B0-920-xx5-17.LBL
Part number: 3B7 920 846 D.
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V07
Encoding: 21116
Workshop #: WSC 00000
No errors found.
Address 19: CAN Gateway
Label file: RKS\6N0-909-901.LBL
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001.
Encoding: 00006
No errors found.
Address 37: Navigation Label file: RKS\3B0-919-887.LBL
Part number: 3B0 919 887 E
Component: Navigation BNO 0304
Encoding: 00002
Workshop #: WSC 61832
No errors found.
Address 46: Comfort System
Label file: RKS\1C0-959-799.LBL
Part number: 1C0 959 799 B.
Component: 6Y Comfort Device HLO 0003.
Encoding: 00259
Part number: 1C1959801.
Component: 6Y Steering wheel.FS KLO 0002
Part number: 1C1959802.
Component: 6Y Throttle control.BF KLO 0002
Part number: 1C0959811.
Component: 6Y Throttle control.HL KLO 0004.
Part number: 1C0959812.
Component: 6Y Throttle control.HR KLO 0004
No errors found.
Address 55: Headlight range adjustment. Label file: RKS\4Z7-907-357.LBL
Part number: 4Z7 907 357.
Component: dynamic LWR D07.
Encoding: 00008
No errors found.
Address 56: Radio Label file: RKS\3B0-035-186.LBL
Part number: 3B0 035 186 D
Component: Radio BNO 0304.
Encoding: 05417
"One error found:"
00853 - Rear speakers.
36-00 - Interruption.
Address 57: TV Tuner
Label file: None
Part number: 3B0 919 146.
Component: TV Tuner H05 0704.
Encoding: 0000070
No errors found.
Address 58: Auxiliary tank
Label file: RKS\3B7-906-268.LBL
Part number: 3B7 906 268.
Bauteil: Kraftst. Auxiliary tank 0004.
No errors found.
"Ende" translates to "End" or "The end" in English.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Monday, March 24, 2008, 12:05:37:46308
Address 03: Brakes/ABS.
Control unit part number: 4B0 614 517 E.
Component and/or version: ABS/ESP, all-wheel drive, 1728.
Encoding: 00000
Workshop Number: WSC 00000
2 errors found:
01044 - Control unit incorrectly coded.
35-00 - -
00778 - Steering angle sensor (G85).
66-10 - Synchronization not performed - Intermittent.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Die Blumen blĂŒhen in allen Farben, und der Duft von frisch gemĂ€htem Gras liegt in der Luft. Die Kinder spielen ausgelassen im Sandkasten, und die Erwachsenen entspannen sich auf den BĂ€nken und unterhalten sich angeregt. Es ist ein perfekter Sommertag."
Saturday, March 22, 2008, 2:08:15 PM: 46308
Address 01: Engine.
Control unit part number: 07D 906 018 C.
Component and/or version: B5S-4.0L-AG G 4658.
Encoding: 00173
Workshop number: WSC 43524.
Extended information: WVWZZZ3BZ2E370981 VWZ7Z0A4567481
2 errors found:
P1347 - 35-00 - -
18060 - Please read the error memory of the transmission control unit.
P1652 - 35-00 - -
Readiness: 0000 0000
Monday, March 24, 2008, 11:27:00:46308
Address 01: Engine.
Encoding: 00173
2 errors found:
P1347 - 35-00 - -
P1652 - 35-00 - -
Monday, March 24, 2008, 17:02:03:46308
Address 01: Engine.
Encoding: 00173
"One error found:"
P1347 - 35-00 - -
How am I supposed to handle this?
I had the last scan a while ago, but I haven't noticed any malfunctions.
Login from table.
2. Encoding from table.
3. Turn the steering wheel at least 30 degrees and then return it to the center position.
4. Check measurement block 005.1.
5. Login activation - default setting.
6. Default setting: MWB 001.
I have corresponded with the coding department using code 05397, and the login is 08497.
Okay, but what exactly do I need to do after the second step?
Please help.
Translated on 16-10-2026, 10:37.
Back to top Profile PM Email
Benni
Post09-04-2008, 8:02    Subject: ABS Coding: Explained & How It Works Quote
What does "gespielt" mean?
Did you only read and clear the error memory, or did you also make changes to the logins, codings, and configuration channels?
"I'm a beginner myself, but I don't think it's going to be easy to fix this."
Passat Variant Highline 3BG EZ 2/04 2,0 TDI mit DPF 235tkm 2x DPF gespĂŒlt - RIP dank LKW
Translated on 16-10-2026, 10:57.
Post09-04-2008, 8:43    Subject: ABS Coding: Explained & How It Works Translating...
[Translating...]
http://wiki.ross-tech.com/index.php/VW_Passat_(3B)
No new posts Read Error Codes: How To & Troubleshooting On-Board Diagnostics (OBD)
