ECU 028 906 021 AT: Where does it fit?
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post14-07-2007, 10:47    Subject: ECU 028 906 021 AT: Where does it fit? Quote
Engine control unit 028 906 021 AT - where does it belong?
According to the seller, it's a Passat with a 1Z engine, manufactured in 1996, with a mileage of 15,000 km.
Is that correct?
Thank you and best regards.
Jens.
Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 29-10-2026, 4:40.
Jens 16syncro
Post15-07-2007, 10:01    Subject: ECU 028 906 021 AT: Where does it fit? Quote
mullemaus wrote:
Regarding the control unit, it should be one that was used from 1994 onwards. I mean, it might even be one without WFS. icon_wink.gif
I always thought that MSG (Message Service) without WFS (Web Feature Server) was only available starting with MSA15.
How can you find out if something is without a WFS?
(Okay, you can plug it in and try it out...)
Jens.
Translated on 29-10-2026, 4:41.
Post15-07-2007, 12:18    Subject: ECU 028 906 021 AT: Where does it fit? Quote
Is that correct?
Okay, please provide the text you would like me to translate from German to English.
Translated on 29-10-2026, 4:42.
Rudi
Post15-07-2007, 14:29    Subject: ECU 028 906 021 AT: Where does it fit? Quote
I always thought that MSG without WFS is not available for MSA15 or higher.
It aligns with my experiences. The '94 Passat came standard with WFS on some models.
I'm pretty sure that one belongs to the 1Z group.
Rudi
Translated on 29-10-2026, 4:43.
B4 killler
Post06-04-2008, 11:58    Subject: Defective Control Unit: Symptoms & Repair Quote
Did my 1Z engine have air in the diesel line?
Okay, I fixed it. Also, regarding the keywords, we have "leaks," "hoses," "filter," and the pump was from Bosch.
Föder started, began to sputter, vented through the nozzles, and then started running smoothly icon_razz.gif.
The error memory shows error code 37 10, indicating a sporadic control unit defect.
It reappears immediately after being deleted.
Press the accelerator (makes a whistling sound like air being released) engine off icon_evil.gif icon_question.gif
A friend of mine who works at VW mentioned the engine control unit.
The error could also be caused by the chip that is installed from the factory (Öttinger).
028 906 021 AT
0281001 368/369
Which engine control units (ECUs) are compatible?
Translated on 29-10-2026, 4:45.
Wiesel
Post07-04-2008, 8:34    Subject: Defective Control Unit: Troubleshooting & Repair Quote
The error could also be caused by the chip that is installed from the factory (öttinger)
Can, but doesn't have to.
028 906 021 AT
0281001 368/369
The 021AT was never officially replaced (and is therefore still valid).
However, other vehicle identification numbers included 021FC, 021FF, and 021FG.
I still have a TCU (Transmission Control Unit) that is compatible with the 021FC (if you are interested, please send me a private message).
Best regards, Micha.
Translated on 29-10-2026, 4:47.
No new posts Boost Gauge: Essential for Every TDI Engine Troubleshooting & Guides
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Part Number: Find Car Model by Control Unit. Diesel Engine Technology
No new posts Engine Control Unit 1Z Diesel Engine Technology
No new posts T5 Engine Control Unit (ECU) On-Board Diagnostics (OBD)
No new posts A6 C4 TDI Engine Control Unit On-Board Diagnostics (OBD)
