Audi TDI AEL: Starting Problems & Troubleshooting
Go to page: 1, 2  Next
Honk
Post30-06-2008, 13:33    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Hi.
I know this topic has been discussed here many times before, but I couldn't find anything relevant in my search.
'I have to crank the engine for a very long time whenever it's been sitting for a while. When it finally starts, it smokes quite a lot at first. The injection timing is set early ---> according to the workshop. However, I'll have it checked again this week and get the values written down or printed out.'
What other possibilities might there be? It's quite warm outside icon_cool.gif. Or, how could I test these relatively easily and inexpensively?
Last year, new or refurbished diesel injectors were installed.
greetings
Translated on 08-09-2026, 14:53.
olli
Karma: +46 / -0   Thank you, like it!
Post30-06-2008, 14:32    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
"to stand for a long time" or "to stand for extended periods"
Is the diesel filter or its supply line leaking, causing it to slowly drain towards the fuel tank and requiring it to be bled again before starting?
You could try parking downhill and then see if it works.
Best regards from Berlin.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 08-09-2026, 14:54.
Honk
Post30-06-2008, 15:45    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
'Lange stehen' means standing for a long time, either from evening until morning, or from the start of work in the morning until the end of the workday in the evening.
Unfortunately, I can't stay still for very long when going downhill.
greetings
Translated on 08-09-2026, 14:55.
olli
Post30-06-2008, 17:58    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Then, when checking the organ, take a look at the hoses connected to and from the diesel filter, especially if they are transparent. (Ideally, someone else should start the engine). If you see a lot of air bubbles, you can assume there is air in the system. New hose clamps often work wonders. Mine had the same problem, and I replaced the standard pinch clamps with screw-type clamps, and everything was fine.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Honk
Post07-07-2008, 7:23    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Then, check the hoses connected to and from the diesel filter, especially if they are transparent. (Ideally, someone else should start the engine). If you see a lot of air bubbles, it's likely there's air in the system. New hose clamps often work wonders. Mine had the same problem, and I replaced the standard pinch clamps with screw-type clamps, and everything was fine.
Olli
Hi.
Okay, finally found a second man or woman icon_cool.gif. Air bubbles have appeared in the transparent tube. What possibilities are there to limit the 'air intake'? Could it really only be due to the hoses, or are there other causes?
Okay, so if it's running, I turn it off and then start it again, and it starts up. It seems like that's the apparent cause.
greetings
Translated on 08-09-2026, 14:57.
Post07-07-2008, 8:51    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Okay, then it's a good idea to check all hose connections, including the fuel lines and fuel filter, all the way to the tank.
Translated on 08-09-2026, 14:58.
Honk
Post09-07-2008, 9:52    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Hello.
I just had the values read out: the first value is 48, and the second value is 28. It seems to be in the lowest range, which suggests a problem is being detected.
However, the error log indicated a 'fluctuating signal' from the needle lift sensor.
I'm working on the connections. It will probably be something that happens over the weekend. I hope to finally pinpoint or solve the problem by then. icon_cool.gif
Greetings.
Translated on 08-09-2026, 14:59.
TDI-Quattro
Post21-07-2008, 15:02    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Hey, any progress on your issue? Did you replace the hoses/clamps? Did it get any better?
Translated on 08-09-2026, 15:00.
Honk
Post05-08-2008, 15:59    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Hi, has anything changed with your problem? Have you replaced the hoses/clamps, has it gotten any better?
Hello.
I was on vacation icon_cool.gif. Unfortunately, no icon_rolleyes.gif. I think it's getting worse. So, I checked all the hoses/clamps and either inspected them or replaced them.
The problem persists: It takes a long time for the engine to start, and it runs roughly afterwards. If I turn it off as soon as it starts running smoothly and then restart it a few minutes later, the engine starts misfiring again, for some reason. However, if I drive a few kilometers, everything works fine.
Does anyone have any other suggestions? It's always embarrassing when the car doesn't start for what seems like 'hours.'
Greetings.
Translated on 08-09-2026, 15:01.
Honk
Post17-09-2008, 6:57    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Hello.
The problem is still there and it's annoying icon_evil.gif. So, I replaced the diesel filter, and I even installed a check valve between the filter line and the pump, but it didn't solve anything. My workshop foreman still thinks it's the pump itself, hmm... Before I install a new one for a lot of money or have it disassembled, what else can I do?
By the way, does anyone know about batteries from the company Optima, specifically the red and yellow ones?
Greetings.
Translated on 08-09-2026, 15:02.
Post17-09-2008, 8:44    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Have you managed to remove those air bubbles from the diesel line yet? If not, start there. For testing, add more clear sections of tubing (before/after the diesel filter, before and after the return line, near the tank, etc.). Then you can see from which point the air bubbles increase, and you can pinpoint the leak.
Without knowing the exact source of the air itself, no one here will be able to help you.
Guste.
Translated on 08-09-2026, 15:03.
Honk
Post17-09-2008, 9:38    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Have you at least managed to remove the air bubbles in the diesel line yet? If not, start there. For testing, insert more clear hoses (before/after the diesel filter, and before and after the return line, near the tank, etc.). Then you can see from which point the air bubbles increase, and you can find the leak in that way.
Guste.
Return line?? Hmm, I just thought the supply line was important. icon_redface.gif Then I'll have a little fun. icon_wink.gif
greetings
Translated on 08-09-2026, 15:04.
Post17-09-2008, 14:45    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Honk wrote:
Return pipe?? Hmm, I just thought the supply pipe was important. icon_redface.gif
Wrong guess icon_wink.gif.
When the engine is cold, the return line is short-circuited with the supply line (using a device often called a "Knackfrosch" on the diesel filter) to allow the diesel fuel in the small circuit to warm up faster near the pump. Try searching online; you'll find a lot of information on this topic (keywords: "Knackfrosch," "KGR," "diesel circuit," etc.).
Translated on 08-09-2026, 15:06.
Honk
Post19-09-2008, 7:02    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
SUper, now I'm stranded icon_evil.gif. It suddenly stopped working, and there's air in the line between the filter and the ESP icon_evil.gif. I was planning to replace or inspect all the seals, etc., on the return line this weekend. Great. I've been having the starting problem for a while now, and the question is, why did it shut off while I was driving icon_cry.gif? Last weekend, I 'only' installed the filter and a check valve between the filter and the ESP. The filter was an aftermarket part, hmmm.
Can someone tell me what torque (in Nm) I should use to tighten the hollow screw on the filter?
What do you think, is the 'dirt' a filter or just random noise?
Greetings.
Bernd.
Translated on 08-09-2026, 15:07.
Honk
Post23-09-2008, 10:10    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Hello.
The issue with the filter is resolved; it was my mistake icon_redface.gif. However, the starting problem hasn't changed icon_cry.gif. And no more air bubbles are coming through the hose.
There must be another possible reason for this, right?!!
Greetings.
Translated on 08-09-2026, 15:08.
Diesel_Rudi
Post27-10-2008, 10:45    Subject: Audi TDI AEL: Starting Problems & Troubleshooting Quote
Hi! I suspect that the distributor body of your injection pump has already failed. Unfortunately, it's a wear part. The starting speed is significantly lower than the idle speed. This means that the leakage between the pump cylinder and the plunger is greater. This could mean that the starting amount is not sufficient to start the engine. The AEL engine has definitely exceeded 200,000 km.
Best regards, Rudi.
Translated on 08-09-2026, 15:09.
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Sliding Door: Repair & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat 3B, Seatbelt front does not retract properly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 Allroad: Starting Problems & No Acceleration Diesel Engine Technology
No new posts Audi 3.0 TDI ASB starts very poorly, no more ideas! Diesel Engine Technology
No new posts VW T4 Diesel: Starting Problems & Troubleshooting Diesel Engine Technology
No new posts AFN 110 PS: Cold Start Problems & Solutions On-Board Diagnostics (OBD)
