see:
/viewtopic.php?t=18548&start=0&postdays=0&postorder=asc&highlight=&sid=c1e10fc71fd890128504261b0b8f8d42
Boost pressure, over and under. Undercut at
ASZ series, upgraded with new VTG (Variable Turbine Geometry) turbocharger, mass airflow sensor (MAF), and magnetic valve for the lambda sensor.
| Description: |
Vollastbeschleunigung im 4. Gang
bei 1970 U/min 1,68 Bar IST zu 1,356 Bar SOLL (Umgebungsdruck 949mbar) |
| File size: |
82.21 KB |
| Viewed: |
708 times |
| Description: |
| abwechselnd Volllast und Teillast |
| File size: |
93.09 KB |
| Viewed: |
824 times |
| Description: |
| MWB 4,3,8 von 1000-4100 U/min Volllast |
 Download |
| File name: |
LOG-01-004-003-008.xls |
| File size: |
26 KB |
| Downloaded: |
344 times |
| Description: |
 Download |
| File name: |
LOG-01-004-xxx-xxx.xls |
| File size: |
17.5 KB |
| Downloaded: |
367 times |
| Description: |
 Download |
| File name: |
MWB_3_8_10.xls |
| File size: |
25 KB |
| Downloaded: |
327 times |
| Description: |
 Download |
| File name: |
LOG-01-011-SD.xls |
| File size: |
33.5 KB |
| Downloaded: |
297 times |
| Description: |
| bei abwechselnd Teil-u. Volllast MWB 11 geloggt |
 Download |
| File name: |
MWB11.xls |
| File size: |
28 KB |
| Downloaded: |
332 times |
| Description: |
 Download |
| File name: |
MWB11_Volllast.xls |
| File size: |
26 KB |
| Downloaded: |
422 times |
Gruß Tobi
_________________
A3 8L1 PD ASZ EZ 06/02
Seriendatenstand
MSG 038906019 FT / 1,9l R4 EDC G000SG 1527
Laufleistung 120.000km
Translated on 06-07-2026, 20:46.
