Buying Advice: A4 Avant B6 96kw
bastion
Karma: +6 / -1   Thank you, like it!
Post10-05-2008, 15:52    Subject: Buying Advice: A4 Avant B6 96kw Quote
I am planning to buy a new car. I test-drove it today and also made a long trip. What I noticed is that he only reaches his full boost pressure around 1900 rpm, and the LMM (lambda sensor) starts to drop around 3400 rpm.
I would also be interested in typical weaknesses of the model.
Since I don't know the engine, I would like the professionals here to take a look at the log.
The vehicle is a 2002 model and has an AWX with a 5-speed manual transmission.
/my.php?image=logae1.jpg" target="_blank" class="postlink" rel="nofollow">[img][/img]
LOG-01-003-008-0121.CSV
 VCDS-Log
VCDS-Log
 File name:  LOG-01-003-008-0121.CSV
 File size:  2.03 KB
 Downloaded:  590 times
A4 Avant 08/01 AWX 05/08-
No new posts Buying guide for A4 2.5 TDI Diesel Engine Technology
No new posts Buying guide for TDI engines Diesel Engine Technology
No new posts Passat TDI: Buying Guide & Specs (AFN) Diesel Engine Technology
No new posts Passat 3C buying guide Diesel Engine Technology
