[Gasoline Engine] A3 8L AGN: No throttle interruption
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
wolfi_b
CAN Support
Post14-07-2007, 20:52    Subject: [Gasoline Engine] A3 8L AGN: No throttle interruption Quote
Hello!
My brother's 7/96 A3 is giving me a headache again. It's an AGN (1.8L inline-4 engine with 125 horsepower) and the problem is that the engine speed decreases very slowly when I take my foot off the accelerator. He does this while driving and also when stationary.
I've made several logs today, and, in my opinion, the throttle shut-off isn't working.
The logs were created by suddenly pressing the accelerator to full throttle and then immediately releasing it.
Here you can see how long it takes to reach the idle speed:
" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusĂ€tzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema fĂŒr andere Leser nutzlos!
Bitte nutze 'Attachment hinzufĂŒgen' bzw. das Upload Forum hier.
" target="_blank" class="postlink" rel="nofollow">http://img297.
/img297/2447/log1yj4.gif[img][/img]
The diagram was created based on MWB 4 and 5. Don't be alarmed, the speed is only displayed up to a maximum of 2550 RPM in the MWB 5.
But what I find interesting is this log:
" target="_blank" class="postlink" rel="nofollow">http://img159.
/img159/1691/log2vz4.gif[img][/img]
In the yellow-marked area, the STG has detected the overrun (overrun) and yet, injection is still taking place.
The vehicle does not have a clutch pedal or an electronic gas pedal. The thruster switch appears to be working (I haven't found anything in the MWBs, but the operational status is being correctly recognized)
Does anyone have any ideas?
Best regards, Wolfi
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Post14-07-2007, 23:33    Subject: [Gasoline Engine] A3 8L AGN: No throttle interruption Quote
Does this thing have GRA?
If a short circuit occurs in the GRA-STG, the signal from the speed sensor is suppressed and no longer reaches the MSG. This can also produce similar effects.
The issue with the sender can also occur when an external radio source interferes with the signal.
wolfi_b
CAN Support
Post16-07-2007, 18:52    Subject: [Gasoline Engine] A3 8L AGN: No throttle interruption Quote
Hello Roger!
Nö has no GRA. Whether the speed signal is still reaching the MSG, I will check. But only on the weekend, I won't be able to get my hands on it before then.
However, the problem also occurs when the system is running, so is the speed signal then not excluded?
1993 Audi 80 B4 1Z
docmorris-17
Post29-05-2008, 19:40    Subject: What happened next??? Quote
I'm having the exact same problem, has it been resolved???
I really need a solution!
docmorris-17
R.M.
Karma: +14 / -0   Thank you, like it!
CAN Support
Post30-05-2008, 11:40    Subject: [Gasoline Engine] A3 8L AGN: No throttle interruption Quote
Wie sieht es denn mit dem Kupplungsschalter unten am Pedal aus? Gibt es sowas beim Benziner? If so, does it work?
Post30-05-2008, 15:41    Subject: [Gasoline Engine] A3 8L AGN: No throttle interruption Quote
On the Polo 9N gasoline engine without a particulate filter, you can definitely find one. And a defect manifested exactly as described here...
No new posts 1.4 16V (Benziner) AGR-Probleme Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts Kostenvergleich: Diesel oder Benziner? Technical Articles
No new posts Volvo V70 with Audi AEL 2.5TDI - No Power Diesel Engine Technology
No new posts 10cent Tuning und Schubabschaltung Diesel Engine Technology
No new posts Ab welcher Drehzahl greift die Schubabschaltung? Diesel Engine Technology
No new posts DZR fĂŒr Benziner? Diesel Engine Technology
