2.0L TDI: With or Without Intercooler?
Post03-06-2008, 11:24    Subject: 2.0L TDI: With or Without Intercooler? Quote
Hi.
The attached images suggest to me that the difference between the 2.0 16V TDI engine with an aluminum intake manifold and the one with a plastic intake manifold is primarily related to shifting performance.
Can anyone comment on this?
Ideally, someone else with a 16V TDI engine could chime in with pictures?
 File size:  15.13 KB
 Viewed:  4322 times
 File size:  19.01 KB
 Viewed:  4437 times
 File size:  15.26 KB
 Viewed:  4442 times
Translated on 14-10-2026, 0:43.
vagtuning
Post03-06-2008, 18:58    Subject: 2.0L TDI: With or Without Intercooler? Quote
125 KW has a switchable intake manifold.
 Teil2
 File size:  86.55 KB
 Viewed:  4204 times
 Saugrohr
 File size:  80.24 KB
 Viewed:  4975 times
pschaefer
Post03-06-2008, 21:47    Subject: 2.0L TDI: With or Without Intercooler? Quote
So, at least the vacuum sensor is also installed on the BMN model, even with the aluminum "drinking tube" (although it doesn't drink that much anymore icon_wink.gif).
 File size:  65.42 KB
 Viewed:  8943 times
Translated on 14-10-2026, 0:44.
Post04-06-2008, 8:36    Subject: 2.0L TDI: With or Without Intercooler? Quote
OK, thank you.
I'm familiar with the SSP, but I haven't seen the sentence "the 125 kW version" used in contrast to "the 103 kW version" before.
So, it should be the case that:
BKD: 16 V with rigid pipe.
BNM, BMR: 16 V with bellows.
Cxxx (the CR): 16V with a throttle body featuring adjustable flaps.
Translated on 14-10-2026, 0:45.
Post04-06-2008, 17:25    Subject: 2.0L TDI: With or Without Intercooler? Quote
Hi Martin,
The BRE (103kW) also has it.
vagtuning
Post04-06-2008, 17:28    Subject: 2.0L TDI: With or Without Intercooler? Quote
According to this, the BLB and BNA would also be required, but only in conjunction with an automatic transmission.
Translated on 14-10-2026, 0:46.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Intake Manifold: 16V Models On-Board Diagnostics (OBD)
No new posts A3 8L, year 1999, ALH engine, with and without automatic ... Upload
No new posts AXR Log: 150 Ohm vs. No Tuning Upload
No new posts 2.0 TDI: No Power? Troubleshooting Guide Diesel Engine Technology
