AJT Chip Tuning: Performance & Optimization
mambomamber
Post25-06-2008, 14:57    Subject: AJT Chip Tuning: Performance & Optimization Quote
Hello everyone,
I bought a used VW T4 van!
Since it's producing a lot of black smoke and I've already ruled out any mechanical issues (the EGR valve is also faulty), the question now is whether my van has been chipped.
Can someone provide a knowledgeable opinion on this?
3-8-11-Log-file
/download.php?id=3172
/download.php?id=3173
Fuel injection quantity in the engine control unit (ECU): 001 indicates 42.2 mg/stroke.
It's a VW T4, engine code: AJT, with 88 horsepower, manufactured in November 2002.
"Thank you, best regards."
Translated on 28-08-2026, 4:18.
Wiesel
Post25-06-2008, 15:58    Subject: AJT Chip Tuning: Performance & Optimization Quote
Unfortunately, you cannot access the attachments because the T4 forum requires registration.
Either upload it here to the upload area, or, if that doesn't work, send it to me.
I'm attaching it here.
Best regards, Micha.
Translated on 28-08-2026, 4:20.
mambomamber
Post25-06-2008, 17:30    Subject: AJT Chip Tuning: Performance & Optimization Quote
Already changed!
Translated on 28-08-2026, 4:21.
mambomamber
Post28-06-2008, 14:57    Subject: AJT Chip Tuning: Performance & Optimization Quote
Here's the link to the files again:
vagtuning
Post28-06-2008, 17:55    Subject: AJT Chip Tuning: Performance & Optimization Quote
Well, if I had to put it that way, it definitely deviates from the original series.
The desired dosage should be between 32-36 mg/H.
Smoke + dizziness at 30-35mg/H.
With values around 42, you would likely be significantly above the smoke limit icon_smile.gif.
 Grafik
 File size:  24.69 KB
 Viewed:  1179 times
Translated on 28-08-2026, 4:22.
mambomamber
Post30-06-2008, 13:06    Subject: AJT Chip Tuning: Performance & Optimization Quote
The question now is: Should we retrofit the LLK (likely referring to a specific vehicle or engine component) in the hope that it will no longer produce so much soot?
or play the original software again!???
Translated on 28-08-2026, 4:23.
