bernie123 Blaumann
10-06-2008, 21:07 Subject: 1.4 TDI (AMF) Cold Start Problems at 24° |
Hello forum,
Today, during the "cold start" in bright sunshine with a temperature of 24°C, the car was a bit temperamental. Could it be that the air conditioning needs to be activated immediately during startup?
"asks"
bernie
Translated on 25-10-2026, 14:49.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
10-06-2008, 21:34 Subject: 1.4 TDI (AMF) Cold Start Problems at 24° |
No, is the battery okay?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
bernie123 Blaumann
10-06-2008, 21:41 Subject: 1.4 TDI (AMF) Cold Start Problems at 24° |
The battery was in excellent condition until now, so it always pulled the starter motor through cleanly, and the engine always started within 1-2 seconds.
10-06-2008, 21:57 Subject: 1.4 TDI (AMF) Cold Start Problems at 24° |
I'm on the wrong track... did you install it incorrectly?
You were just asking about the ZR 3-cylinder engine, and now it's not starting well  .
Is the FB (likely referring to a fuel pressure regulator) good? And is the diesel filter hose/connection tight? Is there air in the system?
Translated on 25-10-2026, 14:50.
bernie123 Blaumann
10-06-2008, 22:02 Subject: 1.4 TDI (AMF) Cold Start Problems at 24° |
...it (a2) hasn't been completely disassembled yet. The 90,000 km service is still pending.
Translated on 25-10-2026, 14:51.
10-06-2008, 22:21 Subject: 1.4 TDI (AMF) Cold Start Problems at 24° |
 Then I want to make amends to you, it could have been.
Then the mentioned options remain: air filter replacement, late? How many kilometers/is it close to needing a replacement?
