Long-term consumption display has changed
Klausel
Post24-06-2008, 23:37    Subject: Long-term consumption display has changed Quote
Hello!
I have a question about the MFA consumption display.
The vehicle is a Golf 3, AFN model, manufactured in 1997, with 200,000 km on the odometer.
I've had it for 6 years, and during the first 3 years of ownership...
the displayed average consumption often differs from the actual consumption.
Fuel consumption was checked during refueling - the result was always a slight overconsumption of approximately 0.2 liters per 100 km compared to the displayed value, which is normal.
So far.
For a few months now, I've been doing some moderate tuning, icon_biggrin.gif.
Approximately 130 horsepower, with mostly moderate power output.
The consumption is noticeably lower than before, which is just strange.
that the displayed reading is now approximately 0.2 liters higher than the actual value.
The last measurement was 4.93 liters, while the display showed 5.2 liters.
The change in the display is, at a rough estimate, at least 8%.
The shallower tread depth of the (worn/needing replacement) tires -
Let's say 3mm instead of 7mm - of course, this creates the illusion of a longer distance.
It might be possible to attribute some responsibility to him, but he could never be held responsible for 8%.
Can tuning or any signs of wear affect...?
responsible for the fuel injection pump due to the changed consumption measurement.
to be?
Thank you for addressing this luxury problem!
Greetings, Klaus.
Translated on 06-07-2026, 17:39.
Post25-06-2008, 11:22    Subject: Long-term consumption display has changed Quote
Hello Klaus,
Did you also get new nozzles?
Translated on 06-07-2026, 17:41.
Klausel
Post25-06-2008, 13:29    Subject: Long-term consumption display has changed Quote
I already received those new nozzles from you two years ago (at 160,000 km).
It is quite possible that the change occurred back then.
How can this change be explained?
Regards, Klaus.
EDIT: The nozzle size remains unchanged; I am still using the standard AFN nozzle size.
EDIT2: After reading through several similar threads, I now believe I understand the cause of this phenomenon.
reverse the nozzle replacement.
No new posts Do windows open on their own? General Tips
No new posts Doku A3 8P1, Bodenbelag löst sich Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interior Lights Turn On Late: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Einspritzpumpenförderbeginn verändert sich selbstständig Diesel Engine Technology
No new posts The steering angle at the BRS motor does not change Diesel Engine Technology
No new posts Spritzbeginn has changed after 20,000 km, is this normal? Diesel Engine Technology
No new posts PD-Long-term experiences? Diesel Engine Technology
