You don't need to replace the entire injectors. It is sufficient to replace just the injector nozzles. These are the only wear items and also the only difference between different engine types or tuned vs. non-tuned engines.
"Personally, I wouldn't buy used injectors because they are usually only replaced when they have very high mileage and a correspondingly poor spray pattern, or when someone is trying to sell them on eBay. To overhaul such injectors, the injector nozzle needs to be replaced, and the opening pressure needs to be readjusted."
You can find the injector nozzles, including the adjustment settings, here at the Dieselschrauber shop (shop.dieselschrauber.de).
Translated on 02-08-2026, 23:52.
