Original boost pressure sensor: kPa value.
marcel.d
1997 Volkswagen Golf
Post19-07-2008, 16:34    Subject: Original boost pressure sensor: kPa value. Quote
What is the original boost pressure sensor (intake manifold pressure sensor) pressure in kPa, as measured by the engine control unit (ECU) of a Golf 3 TDI with a 110 hp AFN engine?
"I'm always getting the error codes 'intake manifold pressure control difference' and 'control unit intermittently defective', and I have a sensor installed that reads 250 kPa. However, I've read several times that it should only be 200 kPa."
So, what is correct?
Translated on 11-09-2026, 22:06.
Post19-07-2008, 17:38    Subject: Original boost pressure sensor: kPa value. Quote
250 kPa
No new posts P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Part Number Original PD Fuel Injectors Diesel Engine Technology
No new posts Boost Sensor in ECU? Diesel Engine Technology
No new posts Boost Pressure Sensor 1Z On-Board Diagnostics (OBD)
No new posts Boost Pressure Sensor Audi Diesel Engine Technology
