Problem with an ATM
Schneemann
Avatar-Schneemann
Post20-07-2008, 10:22    Subject: Problem with an ATM Quote
Hello everyone in the forum community,
After searching more or less unsuccessfully, I would now like to turn to you for help.
My colleague has a Cordoba manufactured in November 1998 with the engine code AFN. He's been complaining for weeks that it's producing excessive smoke (dark gray to black, looks like it's coming from a poorly adjusted cheap exhaust system, but he doesn't have one) and that it's difficult to start when the engine is warm.
While driving uphill on the way to work (after about 20 km), the car went into emergency mode.
We then first visually inspected the hoses and the intercooler system, and then we took it for a test drive.
After about 1 kilometer, the emergency mode activated again.
Then I proactively replaced the lambda sensor with a diode.
After traveling approximately 50 meters, there was suddenly a loud knocking noise coming from the front, and black smoke appeared at the rear.
"The diode was removed, and it's working normally again, but occasionally it still goes into emergency mode."
Unfortunately, my OBD adapter recently stopped working, otherwise I would have checked the error codes. But could it be due to a misaligned timing belt, or perhaps something related to the ESP system itself?
I know you can't predict the future, but maybe a small hint would be nice.
Happy Sunday!
Gruß Schneemann
Golf Plus Highline Bj. 09/2010 CFHC. eFH, eSP, Climatronic, PDC, AHK, ABS, ESP, GRA, MFA, LMAA, FDH, BSE, Brenderup Kippi 200 und ne Traumfrau auf dem Beifahrersitz.
Translated on 15-07-2026, 2:22.
bastion
Karma: +6 / -1   Thank you, like it!
Post20-07-2008, 11:51    Subject: Problem with an ATM Quote
When it smokes, it usually doesn't get enough air.
Please check all the hoses and pressurize the intercooler system. So, seal it and pump it up.
A4 Avant 08/01 AWX 05/08-
Translated on 15-07-2026, 2:24.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem: Electronic Parking Brake (S-Tronic) in Audi A4, ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 Steering Angle Sensor Problem: Diagnosis & Repair On-Board Diagnostics (OBD)
No new posts Fitting a rear subframe from an Audi A6 into a Golf? Diesel Engine Technology
No new posts Relay 109: Location for AFN vehicles Diesel Engine Technology
No new posts Idle speed control extreme value on a cylinder, AFB? Diesel Engine Technology
