SBB Wear Indicator: How to Disable/Turn Off
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post15-08-2008, 13:09    Subject: SBB Wear Indicator: How to Disable/Turn Off Quote
"On a T4 2000 with 16-inch wheels and 111 kW engine, the warning light occasionally illuminates intermittently."
I've bypassed all the sensors, but the light still comes on.
The wiring harness on the front, left side is probably defective.
Since the car is regularly maintained anyway, I'd like to deregister it.
Is that possible, and how? AI?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 15-09-2026, 8:37.
Post15-08-2008, 13:24    Subject: SBB Wear Indicator: How to Disable/Turn Off Quote
http://de.openobd.org/vw/transporter_7d.htm#17 says:
ECU coding.
Select STG 17 (combination instrument).
ECU coding -> Function 07.
Encoding number (example): 04142
??xxx: Extra options and additional features.
+00 - no extra options.
+01 - Brake pad wear indicator active.
+02 - Seatbelt warning indicator active.
+04 - Windshield washer fluid level warning indicator active.
icon_smile_thumb_up.gif6 - Navigation active
Translated on 15-09-2026, 8:39.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post19-08-2008, 8:43    Subject: SBB Wear Indicator: How to Disable/Turn Off Quote
Translated on 15-09-2026, 8:40.
