bernie123 Blaumann
03-09-2008, 19:48 Subject: AMF - NW, disconnect |
Hello forum,
I can't find the coolant drain plug on my 3-cylinder AMF A2 engine!
"On which page" would this be found, if the northwest corner has the "fork marking" and is located on page 3Z?
Sure, here's the translation:
"Thanks in advance."
bernie
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
03-09-2008, 20:46 Subject: AMF - NW, disconnect |
You can see it here. However, the locking pin isn't fully inserted. When it's properly seated, it goes in all the way. So, the black lump is touching the northwest wheel.
| Description: |
 Download |
| File name: |
IMG_0039k.jpg |
| File size: |
238.51 KB |
| Downloaded: |
649 times |
bernie123 Blaumann
03-09-2008, 21:20 Subject: AMF - NW, disconnect |
Okay, a picture is worth a thousand words.
I would also like to know if the NW (presumably referring to a specific product or component) is compatible with a fork and a 3Z (likely a model or specification).
hello
bernie
03-09-2008, 21:42 Subject: AMF - NW, disconnect |
Hi!
Unfortunately, I can't tell you that anymore. You can't see it in the rest of the pictures either.
Bye.
bernie123 Blaumann
03-09-2008, 22:00 Subject: AMF - NW, disconnect |
Hey everyone,
Okay, I'll try everything out tomorrow, because in my two manuals (AMF A2, AMF POLO), the wiring is described in two different ways.
Reprogramming A2 TDI (bu*##+verlag): Adjust NW to 4Z and adjust KW timing to approximately 7 o'clock.
Instructions from the internet: Set the NW to 3Z and the KW to approximately 7 o'clock.
hello
bernie
matthiasTDI96 Profi-Schrauber
04-09-2008, 6:26 Subject: AMF - NW, disconnect |
Okay, 4Z at AMF... stick to the Polo!
