AMF - NW, disconnect
bernie123
Post03-09-2008, 20:48    Subject: AMF - NW, disconnect Quote
Hello forum,
I can't find the coolant drain plug on my 3-cylinder AMF A2 engine!
"On which page" would this be found, if the northwest corner has the "fork marking" and is located on page 3Z?
Sure, here's the translation:
"Thanks in advance."
bernie
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post03-09-2008, 21:46    Subject: AMF - NW, disconnect Quote
You can see it here. However, the locking pin isn't fully inserted. When it's properly seated, it goes in all the way. So, the black lump is touching the northwest wheel.
 File name:  IMG_0039k.jpg
 File size:  238.51 KB
 Downloaded:  623 times
bernie123
Post03-09-2008, 22:20    Subject: AMF - NW, disconnect Quote
Okay, a picture is worth a thousand words.
I would also like to know if the NW (presumably referring to a specific product or component) is compatible with a fork and a 3Z (likely a model or specification).
hello
bernie
brezelmann01
Post03-09-2008, 22:42    Subject: AMF - NW, disconnect Quote
Hi!
Unfortunately, I can't tell you that anymore. You can't see it in the rest of the pictures either.
Bye.
bernie123
Post03-09-2008, 23:00    Subject: AMF - NW, disconnect Quote
Hey everyone,
Okay, I'll try everything out tomorrow, because in my two manuals (AMF A2, AMF POLO), the wiring is described in two different ways.
Reprogramming A2 TDI (bu*##+verlag): Adjust NW to 4Z and adjust KW timing to approximately 7 o'clock.
Instructions from the internet: Set the NW to 3Z and the KW to approximately 7 o'clock.
hello
bernie
Post04-09-2008, 7:26    Subject: AMF - NW, disconnect Quote
Okay, 4Z at AMF... stick to the Polo!
No new posts Disconnect the control unit Diesel Engine Technology
No new posts ALH Injector Pump: Disconnect for Timing Belt Change Diesel Engine Technology
