easyDIAG won't accept my log file.
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Balkosan
Post03-10-2008, 18:41    Subject: easyDIAG won't accept my log file. Quote
Greetings.
I tried using EasyDiag for the first time today, but it's not really working out...
The log file contains all the important information (time, RPM, speed) for performance measurement. The example file from easydiag looks the same, and with that file, the program displays the data. However, when I use my own file and enter the weight, temperature, and air pressure, the program doesn't show anything.
"Error! The input is incorrect, or it is not possible to perform the calculation based on the input."
As I said, if I run the example file with the same input, everything works. The data import also works without any problems. So, is the problem with my file?
If you want to give it a try, here's the link online. If anyone can run the file, I would appreciate it if you could send me the results. That's all I really wanted...
Link: http://www.mohlis.de/files/TDI_log_2_081003.CSV
Sure, here's the translation:
"Thank you in advance."
--- mohlis.de ---
Performance Autoparts
Translated on 04-10-2026, 3:27.
Back to top Profile PM Email
Post03-10-2008, 20:52    Subject: easyDIAG won't accept my log file. Quote
Well, this isn't the EasyDiag support forum, is it?
At KPower, there are definitely no problems with VCDS, as it's included with the systems in the shop anyway. icon_wink.gif
Translated on 04-10-2026, 3:29.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "8V0035036G: Missing Label File? Fix Now!" On-Board Diagnostics (OBD)
No new posts Help, my car won't start! Diesel Engine Technology
No new posts TDI Problems? Get Help Now! Diesel Engine Technology
No new posts Chip tuning? 3-8-11 log file! Upload
