snowman24 Guest
12-10-2008, 19:29 Subject: R5 TDI VW Touareg: White/Blue Smoke When Accelerating |
Hello everyone,
I drive a VW Touareg (manufactured in 04/2004) with a manual transmission and the 2.5 TDI (R5) engine, without a DPF (I'm not installing one of those).
For approximately 1.5 years, the engine has had a performance upgrade from MTM, increasing the power from 174 hp to about 204 hp, and the EGR system has been defective since then.
Just now, as I was driving home, I noticed in my rearview mirror, illuminated by the headlights of the car behind me, that I was leaving a blue/white smoke trail whenever I accelerated.
The more gas I give it, the bigger it gets.
I cannot detect any loss of power. Also, it doesn't require any water or oil.
Currently, I have approximately 142,800 kilometers on the odometer.
However, I can't say whether this has always been the case, or whether it's only been happening recently, as I've never noticed it before.
I've always noticed that it produces a lot of black smoke, especially when downshifting or accelerating quickly, even in daylight.
What do you think about this? Should I be worried?
Would it be advisable to read out a few data blocks once, and if so, which ones?
Marcus.
Translated on 28-10-2026, 17:38.
Tribu Blaumann
12-10-2008, 20:29 Subject: R5 TDI VW Touareg: White/Blue Smoke When Accelerating |
Hi...
Okay, I wouldn't bother going through the trouble of reading out any data or anything like that. Just take a look at it during the day. My little 1.9-liter engine, even with a chip, behaves the same way, especially if I've been driving in the city or just on country roads for a while. It's just the soot that comes out when you're driving at full throttle.
If you see it during the day, it's definitely something wrong, but with your 2.5 TDI (R5) engine without a DPF, I don't find that unusual  .
If it bothers you, why don't you install a DPF yourself *smirks*. By the way, my boss has a V10 with a DPF, and when he accelerates, I can play hide-and-seek with the exhaust fumes coming from his car, or I can easily drive another 500 kilometers without accelerating.
hehe
Translated on 28-10-2026, 17:40.
snowman24 Guest
12-10-2008, 21:22 Subject: R5 TDI VW Touareg: White/Blue Smoke When Accelerating |
You're right...
I hadn't even thought about that anymore.
I hadn't been on the highway for about 6 weeks (approximately 2000 km).
It was basically just city traffic and a bit of country road.
Okay... On Tuesday, I have to get back on the highway again.
It will probably fit again.
But, as I said, I definitely won't be installing a DPF.
In my area, a sticker like that won't be necessary anytime soon.
And if so, then yellow is perfectly sufficient.
I really don't need to go to Munich, and as for Nuremberg, that's...
As far as I know, it's not yet planned.
Thank you very much in advance.
Sure, here's the translation:
'Hello'
Marcus.
Translated on 28-10-2026, 17:42.
12-10-2008, 21:52 Subject: R5 TDI VW Touareg: White/Blue Smoke When Accelerating |
Observe the oil consumption for a while longer...
Translated on 28-10-2026, 17:43.
Profile PM WWW Garage |
snowman24 Guest
13-10-2008, 17:24 Subject: R5 TDI VW Touareg: White/Blue Smoke When Accelerating |
Hello Rainer,
alles klar. I will do that.
You're welcome.
Since the last oil change, he's used only about half a liter of oil, and the car has already driven around 18,000 km (longlife).
Last time, he used approximately one liter per 10,000 kilometers. I don't know how much he used before that.
I received the car with freshly done maintenance.
I'm not sure what kind of oil was in it.
Best regards.
Marcus.
Translated on 28-10-2026, 17:44.
