Backpressure Control for AHU and AFN Units
mTDI_im_Bulli
Post16-10-2008, 13:34    Subject: Backpressure Control for AHU and AFN Units Quote
Do the AFN and AHU engines have a controlled turbocharger, or only the AFN? Can I flash an AHU engine control unit (ECU) with an AFN map? (EDC15)
Translated on 18-10-2026, 9:46.
Post16-10-2008, 15:08    Subject: Backpressure Control for AHU and AFN Units Quote
AFN has 110 horsepower and uses VTG = vacuum-operated turbocharger.
AHU is a 1Z engine with 90 horsepower, and the wastegate is a pressure-controlled system.
Whether you can flash it depends on whether the hardware is identical in both. However, both engines were available with different MSG hardware configurations. Therefore, no one can help you without the part numbers.
Whether someone will help you with the chipping process - even with part numbers - remains to be seen icon_wink.gif (especially since you are in a forum of a chip provider).
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 18-10-2026, 9:47.
mTDI_im_Bulli
Post16-10-2008, 18:01    Subject: Backpressure Control for AHU and AFN Units Quote
ok, thank you...
Translated on 18-10-2026, 9:48.
