VW T4 Auxiliary Heater: Diagnosis & Troubleshooting
Octavia_4x4
Post22-10-2008, 23:25    Subject: VW T4 Auxiliary Heater: Diagnosis & Troubleshooting Quote
"The auxiliary heater in our T4 isn't working anymore. The display is okay, but we were told by a workshop that "the control unit" is faulty, and the repair cost would be around 400-500 euros."
Now that I'm doing this professionally and I have VAG-COM, I wanted to try it out.
Does anyone know more? Is this device diagnostic? If so, where is the control unit located in the T4?
(T4 2.5 TDI Syncro, 1999)
Translated on 18-09-2026, 3:01.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post23-10-2008, 8:37    Subject: VW T4 Auxiliary Heater: Diagnosis & Troubleshooting Quote
If it's an Eberspächer unit, the control module (SG) is directly integrated into the heating unit (SH), and it needs to be removed. I suspect the same applies to Webasto units, but I'm not certain.
It can't be repaired; it's beyond saving.
First, you need to determine the type and device number. Bosch can read the error codes using the Eberspächer software. Some can also be read using VAG and VAG-Com, but the diagnostic depth is five times greater with Eberspächer.
Eberspächer's hotline is excellent.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 18-09-2026, 3:03.
michiglaser
2007 Audi A4 Avant
Post23-10-2008, 13:22    Subject: VW T4 Auxiliary Heater: Diagnosis & Troubleshooting Quote
With the older Eberspächer pre-selection timer, the auxiliary heater can be diagnosed via the buttons on the timer itself, without having to remove the control unit or the heater.
It then displays error codes.
At most, it might be necessary to run some cables.
The 1999 model probably already has the blue-lit clock, right?
It doesn't work with that.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 18-09-2026, 3:04.
Octavia_4x4
Post23-10-2008, 14:52    Subject: VW T4 Auxiliary Heater: Diagnosis & Troubleshooting Quote
Yep.
"It already has the newer interior with blue lighting... hmm, so the workshop was probably right with their 500€ estimate. I was hoping that only the control board behind the timer would be damaged."
With the approximately 260,000 kilometers it has now, the €500 is definitely not worth it for those 2 or 3 winters icon_sad.gif.
Translated on 18-09-2026, 3:05.
michiglaser
2007 Audi A4 Avant
Post23-10-2008, 16:06    Subject: VW T4 Auxiliary Heater: Diagnosis & Troubleshooting Quote
I don't know which workshop diagnosed the problem, but I suspect that not many workshops actually have a good understanding of the subject matter.
"In fact, some of the control units in the heating systems sometimes fail (I suspect a D5WS unit is installed). However, often the control unit is simply locked due to operation outside of its specified parameters."
Try having it unlocked at a Bosch service center, or get an old pre-selection clock and do it yourself.
1. Is it an air heater?
2. Check the battery and the relay.
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 18-09-2026, 3:06.
Thomsch
Post07-11-2008, 3:38    Subject: VW T4 Auxiliary Heater: Diagnosis & Troubleshooting Quote
I believe that most auxiliary heating control units have a diagnostic lead (usually green). However, this lead is rarely connected during installation. There is a specific and dedicated pin in the OBD socket for the auxiliary heater.
Best regards.
Thomsch.
Translated on 18-09-2026, 3:07.
schrauber84
Karma: +1 / -1   Thank you, like it!
Post07-11-2008, 22:51    Subject: VW T4 Auxiliary Heater: Diagnosis & Troubleshooting Quote
There are parking heaters where you can read out error codes. These heaters have a clock that can be set. There is a separate device for reading the error memory.
Heating systems that don't have a clock cannot be read out, or at least, not a specific model range.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post08-11-2008, 13:50    Subject: VW T4 Auxiliary Heater: Diagnosis & Troubleshooting Quote
All heaters can be read out - at least those from Eberspächer - but not all with VAG, but rather with the Eberspächer tool. icon_idea.gif
Translated on 18-09-2026, 3:08.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Webasto Heater Diagnosis: Troubleshooting Guide Diesel Engine Technology
No new posts Auxiliary Heater Diagnostics: CD-ROM Guide On-Board Diagnostics (OBD)
No new posts Diagnose Standheizung Galaxy On-Board Diagnostics (OBD)
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
