Valve Stem Guides: Types & Applications
holzbein
Post02-11-2008, 12:01    Subject: Valve Stem Guides: Types & Applications Quote
I'm currently in the process of completely rebuilding my engine. However, I can't find any suppliers where I can order valve stem seals. VW only offers complete cylinder heads, and mine is now completely disassembled and has been machined, so I don't want to reinstall the old ones.
Do you know of any sources?
It is a...
Volkswagen Golf IV 1.9 PD.
74 kW
Arrival: 01/12.
MKB: AXR
Thank you very much.
Translated on 24-09-2026, 7:46.
Post02-11-2008, 12:12    Subject: Valve Stem Guides: Types & Applications Quote
I think the best thing to do would be to take the head to a motor repair shop. They have the right tools to properly install and remove the valve guides without damaging anything.
Translated on 24-09-2026, 7:47.
holzbein
Post02-11-2008, 12:22    Subject: Valve Stem Guides: Types & Applications Quote
We also have the tools and the knowledge. The problem is that we've previously ordered VSF (Viton sealing flanges) from a supplier, but they never fit properly. We always had to painstakingly turn them down to the correct size on a lathe, and with my engine, they are completely off. Perhaps someone knows a manufacturer where this issue doesn't occur.
Translated on 24-09-2026, 7:48.
g1om
Post02-11-2008, 20:24    Subject: Valve Stem Guides: Types & Applications Quote
There might be something available from BMW, but I can't tell you if it will fit.
Sizes 11, 12, 1, and 266 760 are manufactured with a +0.10mm tolerance. They were used with M10 fasteners.
Translated on 24-09-2026, 7:49.
