T4 Engine MKB: Target Values & Specs
Tobi12345
Post01-11-2008, 21:13    Subject: T4 Engine MKB: Target Values & Specs Quote
Good evening, everyone.
Short question: Do the same target values apply to the MKB AUF (motor control unit) in the T4 as they do for the ACV (air conditioning valve)?
regarding the start of injection and everything else?
It's a 2000 model.
The target values for ACV can be found here, but different values should apply for AUF.
Would it be possible for someone to help me with the data?
Tobi.
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Translated on 21-09-2026, 5:51.
Wiesel
Post02-11-2008, 0:19    Subject: T4 Engine MKB: Target Values & Specs Quote
Hi Tobi,
Since the same control unit (018C) was installed in the AUF and the ACV, they should...
Target values should be equal.
Best regards, Micha.
Translated on 21-09-2026, 5:52.
No new posts Target values for 6-cylinder engines. VP AYM Technical Data
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Motor-Sollwerte etc. in Tabellenform? Diesel Engine Technology
No new posts Sollwerte für PD ARL Diesel Engine Technology
No new posts ASZ Setpoints: Values and Configuration On-Board Diagnostics (OBD)
No new posts AU: Setting Abregel Thresholds - Explained Diesel Engine Technology
