Oil Leak: A4 B5 2.5 TDI (1998) - Fix It!
michi22
1998 Audi A4
Post07-12-2008, 11:54    Subject: Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Quote
Hello.
My A4 2.5 TDI, manufactured in 1998, constantly has an oil leak that I can't seem to fix.
The following items have been replaced so far:
-Oil-sealing poetry
-VDD
-ZKD
- Simmering seal, front of crankshaft.
- Oil separator (now a cyclone oil separator is installed).
Furthermore, I added some Wynns Oil Stop Leak, but it didn't improve the situation.
Could it be due to the current oil being used: Mobil 1 0W40?
Michi.
Translated on 10-09-2026, 12:45.
Karma: +807 / -0   Thank you, like it!
Post07-12-2008, 12:16    Subject: Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Quote
Just measure the crankcase pressure.
Translated on 10-09-2026, 12:46.
michi22
1998 Audi A4
Post07-12-2008, 13:50    Subject: Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Quote
How can I measure it?
best regards
Michi.
christians
Post07-12-2008, 23:36    Subject: Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Quote
Manometer with appropriate measuring range or water column. Connect to the oil dipstick.
Gruß Christian
michi22
1998 Audi A4
Post09-12-2008, 21:22    Subject: Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Quote
Where can I get a pressure gauge like that?
Sure, here's the translation:
"A link would be great."
best regards
Michi.
Translated on 10-09-2026, 12:47.
christians
Post10-12-2008, 22:55    Subject: Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Quote
"I have no idea, I just grabbed a natural gas data logger (up to 100 mBar) – I happened to have a few of those lying around... But they cost between 1000 and 2000 euros each, so it's not really interesting."
Gruß Christian
Post11-12-2008, 10:49    Subject: Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Quote
Measurement device for owners of V6 engines with low pressure: You take a transparent tube and hang it in a U-shape, so that the U is, for example, 3 meters high. Then fill it halfway, i.e., 1.5 meters, with water. This results in a measurement range of approximately 0.15 bar.
Use a permanent marker to draw a line at the minimum level. Leave one end of the hose open, and attach the other end to the opening of the dipstick.
Now, the crankcase pressure pushes the water column in the U-tube downwards on one side and upwards on the other. Each 10 cm from the reference line corresponds to 0.010 bar, which is equal to 10 mbar.
I don't know the exact target range by heart, but it was posted somewhere in the forum before. If the water is splashing onto the garage ceiling, you can stop the measurement even without taking any measurements. icon_cool.gif
Translated on 10-09-2026, 12:49.
vwSchrauber
Post11-12-2008, 11:55    Subject: Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Quote
@Rainer: Don't you think that a water column of 1.5 meters would measure a higher pressure than an oil column of approximately 70 cm?
This means that, in the event of a problem, the oil would be pushed out of the dipstick tube before the maximum selected measurement range of 1.5 meters water level is reached.
Translated on 10-09-2026, 12:50.
christians
Post11-12-2008, 20:43    Subject: Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Quote
The pressure should be a maximum of 5 mbar, which is equivalent to 50 mm water gauge. There is no oil anywhere, as the measuring tube does not extend below the oil level.
Gruß Christian
Translated on 10-09-2026, 12:51.
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Dam... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B2 CV Joint Leak: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wastegate valve clicking constantly? Diesel Engine Technology
No new posts Battery Draining Fast? Common Causes & Fixes On-Board Diagnostics (OBD)
No new posts Ford Galaxy 1998: Specs, Review & Price Diesel Engine Technology
No new posts Passat TDI Flywheel: AFN Engine, 1998 Model. Diesel Engine Technology
