Turbo Question: Get Fast Answers Now!
mhernach
Post18-10-2006, 8:44    Subject: Turbo Question: Get Fast Answers Now! Quote
Hello to the community...
Yesterday, while driving on the highway at 150 km/h, I experienced a turbocharger failure in my Galaxy.
'Now, I can't get a turbo for my Galant because, supposedly, the one from the Golf is rotated 180 degrees, which means the exhaust side is on the other side...'
Is that correct?!?
My turbocharger has the part number N. 028 145 701 QX.
Golf is the same.
Engine: 1Z, manufactured in October 1996, TDI, 90 horsepower.
Installation: When viewed from the front of the vehicle, the intake side is on the right and the exhaust side is on the left, located on the rear side of the engine.
This photo was taken from a low angle, looking upwards.
http://www.mhernach.com/tdi/PREVIEW/02100002.JPG
More photos can be found under http://www.mhernach.com/tdi/PREVIEW/INDEX1.HTM.
Michael.
Translated on 25-10-2026, 19:39.
bloesch
Post18-10-2006, 9:28    Subject: Turbo Question: Get Fast Answers Now! Quote
Hmm... same part number means the same part.
The aforementioned turbocharger was installed in the following models: Golf, Caddy, Sharan, Vento, and others.
Translated on 25-10-2026, 19:41.
werwolf07
Post19-10-2006, 21:03    Subject: Where to buy in Austria Quote
I'm also from Graz - I don't have a minivan, but I found a good AT (automatic transmission) replacement here for my A3.
http://members.aon.at/turbotwins.at/
Maybe this will help!
Post19-10-2006, 21:59    Subject: Turbo Question: Get Fast Answers Now! Quote
Hi.
The photos are all so detailed and taken from such a close range that I can't tell where the wastegate is located.
Here's the installation space for the 1Z turbo from my Golf 3 Variant, manufactured in December 1995 (so, model year 1996), photographed from above - the wastegate is located _in front of_ the exhaust outlet.
 File size:  51.34 KB
 Viewed:  3465 times
Translated on 25-10-2026, 19:42.
mhernach
Post23-10-2006, 6:07    Subject: Turbo Question: Get Fast Answers Now! Quote
Hi everyone...
Since Saturday, I've been driving my big car again...
However, I have to say that I'm a little disappointed...
I'm still having the problem with the lack of power below 2000 rpm... (I'm almost convinced that the old turbo was better.)
Regarding the actual work:
The turbo was installed quickly again. After I finished, the moment of truth arrived... Does it work? Does everything fit?
Starting: Started perfectly, but no turbo whistle was audible at 1500 RPM (all in neutral).
Quickly checked to see if everything is sealed.
Then we'll warm up the engine...
And then it happened: a cloud of smoke, 6 meters by 6 meters, and 4 kilometers long.
Okay, here's the translation:
'Damn, how do we get the oil out of the exhaust? Someone drills a hole in the middle section... lets it drain, and then welds it back up.'
Now I'm driving again... thank goodness... the little Demio isn't really my thing.
Translated on 25-10-2026, 19:44.
mhernach
Post10-12-2008, 9:35    Subject: Turbo Question: Get Fast Answers Now! Quote
Hello everyone, again...
After more than 26 months, my turbocharger has failed again...
Maybe it's a side effect from the tuning after all?!
Okay, so now my actual question...
Sharan 028 145 701 QX
Golf 028 145 702 FX
Does the Golf's engine fit into the Sharan, or not?
I'm starting to feel desperate...
Michael
[img]/download.php?id=3455[/img]
[img]/download.php?id=3456[/img]
[img]/download.php?id=3457[/img]
 File size:  408.09 KB
 Viewed:  628 times
 File size:  382.74 KB
 Viewed:  611 times
 File size:  377.03 KB
 Viewed:  570 times
Translated on 25-10-2026, 19:46.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post18-12-2008, 18:12    Subject: Turbo Question: Get Fast Answers Now! Quote
Hello Michael,
I wanted to have the two loaders, 28 145 701 QX and 702 FX, delivered today and take some pictures for you to see if there are any differences.
I chose the manufacturer BU for this. One charger is called 124156 and the other is 124367. The 124367 is no longer available and has now been replaced by the 124156. So, it's the same charger. It's not very precise, but hopefully this information will be helpful to you.
Steffen.
Passat Variant BGW 2005
Translated on 25-10-2026, 19:48.
mhernach
Post19-12-2008, 9:31    Subject: Turbo Question: Get Fast Answers Now! Quote
Hello...
Having now acquired a reasonably priced turbocharger, including the exhaust manifold, and having already installed it, I can definitively say that the turbocharger from the Golf 1Z is identical to the one from the Seat Ibiza 1Z.
My car is running smoothly again... *lol*
Translated on 25-10-2026, 19:49.
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Passat 1.9 PD: Urgent Question (MJ 08/2000) Diesel Engine Technology
No new posts Question about oil lines for Turbo 1Z - I'm working on it Diesel Engine Technology
No new posts 1.9 TDI PD ASZ Oil on Turbo Diesel Engine Technology
No new posts Turbo AAZ to Turbo 1Z Conversion Guide Diesel Engine Technology
