AWX-Driver Blaumann
2005 Skoda Superb Premium Support
22-01-2009, 20:42 Subject: LLK Scrap: What Now? |
Hello everyone.
Unfortunately, I had a minor collision with a tree stump the other day.
"Fortunately," it happened almost right outside my front door.
Initial damage assessment: OK, bumper torn. And the ventilation grille has fallen off.
This morning, I intended to bring it to work.
As soon as I started driving, I immediately noticed the bizarre hissing sound.
So, I turned it around and parked the car again.
After disassembling the car so extensively today, it was clear that, in addition to the damaged bumper, the radiator was also completely broken.
The entire lower plastic part is completely torn.
The bracket also neatly punched a hole there.
Now, to my question.
Do I really have to install another expensive original part (280€)?
Or would a good one from the accessories market also work?
Are there really such significant differences in performance?
I would also consider a good used one, but even those are being sold for around €150-200 at the major online auction site, which is a very low price.
But that would already be a small saving.
Does anyone happen to have one lying around *looking hopefully*?
I need one for a 1.9 TDI AWX engine, specifically from a Passat or Superb.
Although I have little hope.
I thoroughly inspected the piping, but I couldn't find any fragments.
Is there still a risk, even with overpressure in the system, that small parts could be torn off or have been torn off?
AWX-Driver
ehemals: Skoda Superb 96KW PD MKB AWX,
+ 2-Tank Pölumbau
jetzt: MB W210 E300TD T-Modell 133kW
mit Pölumbau
Translated on 15-10-2026, 23:04.
Profile PM Garage |
hame22 Blaumann
22-01-2009, 22:09 Subject: LLK Scrap: What Now? |
Something from the accessories should also work.
Or you can buy one at an auction. There are many available.
sufficiently.
Translated on 15-10-2026, 23:07.
AWX-Driver Blaumann
24-01-2009, 11:13 Subject: LLK Scrap: What Now? |
Hello everyone.
I decided to go with an original part instead of a replica because I was concerned about the uncertain cooling performance and the sometimes strange dimensions of the replicas.
Can anyone share some information about the issue of charge air cooler pipe contamination?
Should I be worried about that? Or does the air being blown outwards prevent anything like that from happening?
AWX-Driver
+ 2-Tank Pölumbau
mit Pölumbau
Translated on 15-10-2026, 23:08.
Profile PM Garage |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
24-01-2009, 14:02 Subject: LLK Scrap: What Now? |
"The LLD (likely referring to a specific device or component) cannot do anything on its own, but I would definitely clean everything with engine cleaner/brake cleaner before completing the process!"
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
AWX-Driver Blaumann
24-01-2009, 16:31 Subject: LLK Scrap: What Now? |
Hello everyone.
I've already cleaned everything thoroughly.
This oil and soot mixture is also disgusting.
And these quick-release mechanisms certainly aren't the ultimate solution.
They're leaking everywhere.
I have an oil stain on my undercarriage that's about the size of my hand.
I was just concerned that he might have inhaled some crumbs.
Although I haven't found any wilting anywhere.
Neither in the oil residue from the lubricating fluid nor in the pipes.
I'm just hoping for the best.
Thank you.
Here's a picture of the LLK.
| Description: |
| File size: |
81.27 KB |
| Viewed: |
1501 times |
AWX-Driver
+ 2-Tank Pölumbau
mit Pölumbau
Translated on 15-10-2026, 23:09.
Profile PM Garage |
25-01-2009, 12:27 Subject: LLK Scrap: What Now? |
The quick-release fasteners (brackets) can also be replaced  .
Translated on 15-10-2026, 23:10.
EMSimASZ Guest
25-01-2009, 15:05 Subject: LLK Scrap: What Now? |
'I wouldn't buy a used LLK (likely referring to a specific type of engine component) from 'e...' because they often sell LLKs that have been damaged by turbocharger failures. Over time, small pieces can break off, travel through the engine, and then end up damaging the exhaust turbine.'
So, it's best to just stay away from it.
Translated on 15-10-2026, 23:11.
AWX-Driver Blaumann
25-01-2009, 19:03 Subject: LLK Scrap: What Now? |
@ teileklaus
Even if I replace the seals, the oil will still be in there and will eventually leak out.
I think the whole mechanism is complete nonsense.
It would have been better to have clean hoses with proper clamps.
But I personally find it too complicated to replace everything.
@EMSimASZ
That's exactly why I've decided to go with original parts.
AWX-Driver
+ 2-Tank Pölumbau
mit Pölumbau
Translated on 15-10-2026, 23:12.
Profile PM Garage |
