wingmaster Blaumann
Joined: 12/25/2007 Posts: 100 Karma: +4 / -0 Location: Köln
16-12-2008, 21:05 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
As stated in the title, I want to increase the power of my 2003 Golf 4 TDI 96kw ASZ to approximately 200hp.  Mileage: 130,000 km.
I understand that several parts need to be replaced during the performance.
I just bought a brand new GT1749VB. Not yet installed.
New oil supply and oil return lines are also installed.
R32 intake and air filter box are already installed. Air mass sensors and air filters are new.
Ordered: Seat Ibiza Cupra front-mounted intercooler, adapted for use in the Golf 4.
Also, a Sachs performance clutch (organic) has also been ordered. A flywheel is not suitable due to noise.
Since I have an ASZ engine, I have already installed the 550mm nozzles.
Are the 200hp and 400nm figures achievable with these components?
If the head gasket is overheating due to performance, I directly install the 12.9 head bolts from ARL. Are there perhaps stronger screws or bolts?
I wanted to create a kind of progress thread, where I could post my updates.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
16-12-2008, 21:12 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
No, even I realize that something is missing, or have I missed something?  Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
wingmaster Blaumann
16-12-2008, 21:15 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
You mean the chip adjustment  . Yes, it will be installed at the end, once all the components have been fitted.
16-12-2008, 21:22 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
While I don't really care, but if the voting process might be handled by Rainer, then I would ask him beforehand what would make sense to include, even though you already have specific ideas. Gruß, der Teileklaus
wingmaster Blaumann
16-12-2008, 21:31 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
I would prefer to have Rainer do the work, but I live in Cologne, Germany, and traveling to Switzerland for the software customization is a bit too far for me.
16-12-2008, 21:54 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
In Switzerland, it's beautiful - take a vacation  Gruß, der Teileklaus
wingmaster Blaumann
16-12-2008, 22:53 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
That's another thing that comes to mind.
My AGR has been "defective" for ages  . Now I've noticed that the internal components of the AGR are quite large and unnecessarily disturb and hinder the airflow. The AGR actually creates a bottleneck between the LLK (presumably the intake manifold) and the intake manifold.
My idea now is to completely remove the internal parts and weld the holes to eliminate the narrow passage.
Now, however, we also need to consider the auxiliary air intake valve, which is located in the AGR (Exhaust Gas Recirculation) system. Its cross-section also somewhat hinders the airflow. But I think the cross-section of the valve is significantly smaller and it is located much more favorably in the intake manifold. Removing the storage compartment is not an option.
Now my question to the experts. Could this mean anything, or should I save the effort?
RTDI-Tom Guest
17-12-2008, 7:59 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
I would, on this occasion, remove everything and install a replacement pipe. You can buy this ready-made.
Also, auch bei mir ist die Abstellklappe defekt (und ich sage es nicht, ich habe tatsächlich ein Steuergerät, das diese Funktion nicht unterstützt, und es zieht die Klappe jedes Mal sofort zu und schaltet dadurch den Motor ab - dazu gibt es auch einen Thread hier). The perceived difference when stopping is minimal and is only noticeable when the engine is completely cold.
wingmaster wrote: | | I would prefer Rainer to do it, but I am from Cologne, Germany, and driving to Switzerland for the software customization is a bit far for me. | Then you will have to look around for some software that doesn't just say "200PS" but actually has that performance.
Just now, another piece of work from a young, dynamic tuning company has landed on my computer, which supposedly brings a Leon ARL up to 430 Nm / 204 hp (since the software base is the same as the ASZ, this example is already transferable to your case).
If the inner workings of the software are well understood, then real-world figures such as those for the ARL files can be calculated to be approximately 350 Nm and 180 PS. The remaining missing values (including distorted boost pressure diagnostic data and other factors) are the result of various errors and lack of knowledge on the part of the tuner.
Incidentally, the owner of the modified Leon also lost a comparison against a similar car, whose software was cleanly calculated to produce a mere 365 Nm / 185 hp, and did not fare well.
But perhaps it's good that only a tiny fraction of the alleged "> 400 Nm" tuning files for the 1.9 TDI engines actually unleash such power – simply to prevent a continuous failure of clutches and gearboxes, which would damage the tuning industry's reputation for irresponsibility towards customer equipment.
However, if drivers with >400 Nm engines firmly believe in it (because their tuner, of course, has a full plan, otherwise they would have gone somewhere else!), they can calmly argue about it, and otherwise, little damage occurs
Quote: | | My parking flap is also defective (this is no joke, I currently have an ECU in there that doesn't seem to support this function, and it keeps closing the flap immediately, thereby shutting off the engine | It seems like someone simply tried to disable the AGR in the software with minimal effort: this exactly creates that error pattern. Gruß Ulf
Profile PM Garage |
trebor Guest
17-12-2008, 17:41 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
To optimize the software, you could also contact XXX from XXXX. He is a master of his craft.
edit: No advertising please
RTDI-Tom Guest
17-12-2008, 18:43 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
My parking flap is also defective (this is not a joke, I currently have an ECU in which this function does not support, and it closes the flap every time immediately, thus stopping the engine It seems that someone simply tried to disable the AGR in the software with minimal effort: this creates exactly that error pattern.
Maybe, Ulf. I haven't worked with this control device or the software that was on it at the time, but at that time, I simply disconnected the solenoid for the liftgate. Then there was silence, and therefore I now also know how an ASZ / ARL without a closing door feels.
matthiasTDI96 Profi-Schrauber
17-12-2008, 19:47 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
I have edited Trebor's post. Advertising for anyone is not desired here.
EMSimASZ Guest
17-12-2008, 19:55 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
Can the property owner also speak up? I'm sure the public would also be interested in his opinion on the renovation. I would also like to have even larger nozzles installed.
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
17-12-2008, 20:14 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
@ EMSim ASZ:
You can find Rainer's recommendations in the shop. There are quite precise definitions for exhaust nozzles and turbochargers suitable for >200 HP, always with the appropriate MKB.
haithamina 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
17-12-2008, 20:41 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
EMSimASZ wrote: | | can the property owner also speak up? It would definitely also be interesting to the public to hear his opinion on the renovation. I would also install even larger nozzles. |
But he's going to the competition anyway?
You're so funny... I'm going to eat cookies now, that's more sensible.
Profile PM WWW Garage |
wingmaster Blaumann
17-12-2008, 20:54 Subject: Golf 4 TDI ASZ auf 200 PS oder mehr mit Leistungssteigerung |
Hello everyone.
There are some new developments. Intake cooler and clutch are there.
Basically, I could implement everything now.
I need to figure out how to incorporate the charging pressure sensors into the piping to the LLK.
Okay, I've also considered using larger nozzles. But I only want "just" 200 hp, and for that, the 550mm nozzles should be sufficient.
So far, no one has engaged with my theory about cleaning the AGR without internal intervention.
So, that's really incredible, the amount of tissue that's being removed. I am fully aware that I cannot expect any miracles, but even a minimal improvement in responsiveness would be worth the effort.
Rainer K. wrote: | Can the homeowner also speak up? I'm sure the public would also be interested in his opinion on the renovation. I would also like to install larger nozzles.
You're so funny... I'm going to eat cookies now, that's more sensible. |
I will come to you to have my ASZ modified. I don't want just any software, but yours because you really understand engines. I will be driving with a friend and taking turns. I've just calculated the distance. It's 600km from me to CH-9453 Eichberg. That's still doable, just one day of driving. But it's worth it to me if everything goes according to plan afterwards.
Here are a few pictures of the parts that are already here.
 " color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos! Bitte nutze 'Attachment hinzufügen' bzw. das Upload Forum hier. /files/174324246/DSC01000.JPG" class="responsive" alt="http://
Bitte nutze 'Attachment hinzufügen' bzw. das Upload Forum hier. /files/174324246/DSC01000.JPG" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
Bitte nutze 'Attachment hinzufügen' bzw. das Upload Forum hier. /files/174324245/DSC00998.JPG" class="responsive" alt="http://
Bitte nutze 'Attachment hinzufügen' bzw. das Upload Forum hier. /files/174324245/DSC00998.JPG" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
Bitte nutze 'Attachment hinzufügen' bzw. das Upload Forum hier. /files/174324247/DSC01001.JPG" class="responsive" alt="http://
Bitte nutze 'Attachment hinzufügen' bzw. das Upload Forum hier. /files/174324247/DSC01001.JPG" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
