OBD2 Connectors: German Supplier & Distributor
AndyO
Post17-12-2002, 17:16    Subject: OBD2 Connectors: German Supplier & Distributor Quote
under http://www.secoelectronic.de/ , you can order OBD II management connectors. The connector comes with a housing. The price is 15 EUR plus VAT (as of 12/02).
For more information, please inquire via email at the address provided in the URL.
Translated on 26-10-2026, 0:25.
AndyO
Post15-01-2003, 20:21    Subject: Top View vs. Bottom View: Which is Best? Quote
Hello Ulf,
The connectors have finally arrived. I want to make the connection cable. Since the pins are not labeled, I need to know whether the diagram of the connector in the schematic shows the view from the top or from the bottom (this should be specified).
AndyO
Translated on 26-10-2026, 0:26.
Post15-01-2003, 20:33    Subject: Bird's Eye View vs. Worm's Eye View Quote
AndyO wrote:
Since the pins are not labeled, I need to know whether the diagram of the connector in the schematic shows the view from above or from below (this should be specified).
Hi Andy,
The graphic shows the plug from the perspective of the socket. Therefore, the cable comes "from the back".
Is everything alright?
I'll try to convey that in the drawing...
Translated on 26-10-2026, 0:27.
AndyO
Post17-01-2003, 18:35    Subject: eBay: Connectors & Plugs for Sale Quote
Okay, my adapter is finally working. So far, I haven't had any problems.
Regarding the plug:
The shipping costs at sekorüt are 6 EUR (for one connector > 23.40 EUR).
Right now, there are also plugs available on eBay again.
AndyO
Translated on 26-10-2026, 0:28.
No new posts ESP: Connect Contacts to 10-Pin Plugs Diesel Engine Technology
No new posts ESP Connectors: What are the Purple Jumper Clips? Diesel Engine Technology
