Document A6 4B, Fresh Air Blower Control Difference (Solution)
Michael II
Post16-01-2003, 12:04    Subject: Document A6 4B, Fresh Air Blower Control Difference Quote
Fresh Air Blowers V2 - Regulatory Difference, Error Code 01273 - Only applicable to vehicles with sunroof.
Cause
When the 15A circuit breaker is switched on, along with the ignition and air conditioning, a faulty control of the J 309 solar cell disconnect relay can result in error code 01273.
Solution:
For all vehicles with air conditioning and sunroof, after inserting fuse No. 15, the memory of the air conditioning control unit must be cleared before the vehicle is delivered.
Tschüss
Michael II
Ratings - Document A6 4B, Fresh Air Blower Control Difference
No new posts Golf 1J documentation up to 12/00: Whistling noises from ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3138 - Airflow Control Valve: Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Was ist das Steuergerät für Frischluftgebläse? Diesel Engine Technology
No new posts Fresh air blowers without function On-Board Diagnostics (OBD)
No new posts Ladedruck Regeldifferenz AHH On-Board Diagnostics (OBD)
No new posts Intake Manifold Pressure Regulation Difference Upload
