10-03-2009, 19:42 Subject: Crankcase pressure AVF |
Hello.
Here, it's the slight movement of the oil cap that's loosely placed on top of the valve cover.
http://tequila.homeip.net/Passat/MVI3777.html
typical for an AVF (or generally for a TDI engine).
The lid might wobble, but if you tap it lightly and hold it down slightly, it won't pop up.
The car is a 3 Series BMW from 2002 and has 126,000 kilometers on the odometer.
Translated on 19-07-2026, 9:11.
Profile PM Garage |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
10-03-2009, 20:58 Subject: Crankcase pressure AVF |
I would consider that to be harmless.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 19-07-2026, 9:12.
Profile PM Email Garage |
kanud Blaumann
10-03-2009, 21:39 Subject: Crankcase pressure AVF |
It looks the same at an outpatient clinic.
The lid rattles when it's loosely placed on top, but it doesn't get pressed down even when you gently push it.
Held467 Blaumann
10-03-2009, 22:01 Subject: Crankcase pressure AVF |
Does my AFN also?
Translated on 19-07-2026, 9:13.
10-03-2009, 22:02 Subject: Crankcase pressure AVF |
Hi Martin, let's be constructive about this:
Könnte man nicht einen Deckel bohren und mit einem Anschlussnippel mit Drossel und/oder Rückschlagventil versehen, dann könnte man wissenschaftlicher an Grenzfälle herangehen und richtig messen. A
So, with a cheap water column in the splash guard hose and a scale.
Possibly fill it with thick oil; that would eliminate the need for a throttle!  }So, with a cheap water column in the splash guard hose and a scale.Possibly fill it with thick oil; that way, it saves the throttle! }
matthiasTDI96 Profi-Schrauber
11-03-2009, 8:54 Subject: Crankcase pressure AVF |
Even though it might not have any scientific value, my car dealership sees things the same way. It was also the case with the used vehicle I sold a while ago, which had about 160,000 kilometers on the odometer...
Translated on 19-07-2026, 9:14.
11-03-2009, 9:06 Subject: Crankcase pressure AVF |
"Scientifically speaking, using a universal cap and measuring cold/warm values across different engines allows for establishing a reference point, determining the variability, and obtaining results in seconds."
Translated on 19-07-2026, 9:15.
11-03-2009, 9:13 Subject: Crankcase pressure AVF |
Do all Volkswagen oil filler caps fit each other?
Okay, I'll build something like that.
I only know that my cap, which is labeled with the CASTROL brand, always fits very tightly in the SMC valve cover... sometimes it's so tight that I can't even open it by hand.
Profile PM Garage |
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
23-03-2009, 16:30 Subject: Crankcase pressure AVF |
I just changed the oil. It looks exactly like it does in the video for the automatic transmission.
haithamina
Translated on 19-07-2026, 9:16.
