Crankshaft Sensor 1Z
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post20-05-2009, 13:59    Subject: Crankshaft Sensor 1Z Quote
Hi there,
The older 1.9 TDI engines have a crankshaft sensor that is mounted into the engine block. A "toothed wheel" is attached to the crankshaft and is read by the sensor.
What signal does the sensor output?
Could the signal be evaluated using an external display device (e.g., a universal tachometer)?
Due to mTDI, my sensor is no longer working, and I'm considering using it for a different purpose.
Jens.
Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 22-08-2026, 0:46.
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post28-05-2009, 17:27    Subject: Crankshaft Sensor 1Z Quote
This disc is constructed similarly to the metal plate in a distributor, where the hall sensor is mounted, with a total of 4 slots (at least this is the case for VW/Audi) - only slightly larger.
Normally, a rectangular signal should come out of it, but I don't know how it's wired.
Of course, you must switch to an 8-cylinder setting on a universal tachometer because the crankshaft rotates twice as fast as the "distributor" icon_wink.gif.
Translated on 22-08-2026, 0:48.
No new posts VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment Gasoline Engine Technology
No new posts Same error code despite new crankshaft sensor?! Diesel Engine Technology
