Question about fuel injectors
wolle
Post21-01-2003, 11:45    Subject: Question about fuel injectors Quote
Hello everyone,
I would like to know the following:
If you have the injectors tested at a Bosch service center, they can only check the first stage. If the first stage is okay, does that mean the second stage is also okay?
I have a 5-cylinder TDI engine with 140 horsepower and the engine code AEL. I mention this so you know which injectors we're talking about.
Thank you and best regards.
Wool.
Translated on 10-07-2026, 16:38.
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Fuel Injector Part Number: Find Yours Now! Diesel Engine Technology
No new posts Fiat Barva JTD: Questions about Injectors? On-Board Diagnostics (OBD)
No new posts Einspritzdüsen vom ASV in den ALH Diesel Engine Technology
No new posts Fuel Injectors: Types, Function & Replacement Diesel Engine Technology
