Markus D. Guest
27-01-2003, 14:45 Subject: Spark plugs are oily!! |
I recently worked on an Audi A4.
2.5L TDI 110KW: Glow plugs were replaced, and it was discovered that two of the plugs (on the same side of the engine) were heavily oiled. I can't explain this, as the engine doesn't have abnormally high oil consumption. Could it be the head gasket?
Markus D.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
27-01-2003, 21:50 Subject: Spark plugs are oily!! |
Hi Markus,
Always include the mileage  .
Are you sure it's not a mixture of soot and diesel? -> The injectors are leaking!
Is condensation excluded due to a previous short trip?
Best regards, Christian.
Markus D. Guest
28-01-2003, 9:13 Subject: Spark plugs are oily!! |
The vehicle has approximately 100,000 km on it. I've also considered the possibility of a faulty fuel injector. However, it's definitely engine oil, and the spark plug hasn't been fouled. Last summer (at around 90,000 km), the engine received a new turbocharger because the old one was leaking oil. But that's probably not the source of the problem (since it only starts at the manifold).
Markus D.
haehnlein Schrauber
28-01-2003, 12:55 Subject: Spark plugs are oily!! |
hmm, so if the engine doesn't consume any oil (can you manage 15,000 km without topping it up??), then the most I can imagine is an air swirl, for example, caused by deposits in the intake manifold (->from the exhaust gas recirculation system), that constantly carries the fine oil droplets in the intake air there  . But that's just speculation.
I can't imagine a blown head gasket with that mileage! Try opening the oil filler cap while the engine is running... if a hurricane of air rushes out, then the head gasket is definitely gone. However, I still don't know how the oil could get there while the engine is running.
D. Guest
29-01-2003, 19:54 Subject: Spark plugs are oily!! |
'Who here can manage 15,000 kilometers with a TDI engine without needing to refill?'
haehnlein Schrauber
29-01-2003, 21:31 Subject: Spark plugs are oily!! |
D. wrote: | | Who here manages to drive 15,000 KM with a TDI without needing to refill? |
My father has an Audi 80 TDI 1Z, manufactured in 1994, with 270,000 km on the odometer (the oil level is then at the minimum mark).
christians Profi-Schrauber
29-01-2003, 22:15 Subject: Spark plugs are oily!! |
I. Gruß Christian
joergs Guest
29-01-2003, 22:52 Subject: Spark plugs are oily!! |
Me too! Passat 1.9 TDI, 1Z model, manufactured in 1995. 198,000 km.
Hi Jörg.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
29-01-2003, 22:54 Subject: Spark plugs are oily!! |
Me too.
Golf IV, engine code AJM, manufactured in 2001. A3, engine code AHF, manufactured in 2000. Tschüss
Michael II
Uwe Profi-Schrauber
Joined: 04/15/2002 Posts: 1004 Karma: +5 / -0 Location: Westerwald
29-01-2003, 23:38 Subject: Spark plugs are oily!! |
Me too.
A4 AJM with 50,000 km and A3 AHF with 150,000 km, both with a chip tuning upgrade.
Uwe
Markus H. Guest
30-01-2003, 1:10 Subject: Spark plugs are oily!! |
Me too.
(Cars, see 'below')
Alois Guest
30-01-2003, 9:40 Subject: Spark plugs are oily!! |
You don't need to top up anything between oil changes (every 15,000 km). Maximum difference: 1/4 liter. (Golf IV, 90 hp, manufactured in 1998, 130,000 km).
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
30-01-2003, 11:14 Subject: Spark plugs are oily!! |
AHF engine with 130,000 km. If I drive "normally," I don't need to add any oil. However, when driving with a lot of full throttle and high RPMs, I have to add about half a liter every 10,000 km.
With my old turbocharger at a mileage of 82,000 km, the oil consumption could reach as high as 0.5 liters per 1000 km when driving aggressively and using thin oil.
Profile PM WWW Garage |
Manuel Thomas Guest
31-01-2003, 21:33 Subject: Spark plugs are oily!! |
AFN, 197,000 km. Maximum fuel consumption: 0.2 liters per 10,000 km with a chip tuning upgrade providing 140 hp / 305 Nm of torque.
Besides the water pump, everything else on the engine is original!
MOBIL 0W-40
Manuel.
