Okay, so I replaced both microswitches on the driver's and passenger's doors, as suggested.
Everything is now working correctly on the driver's side door (the door light is on, the warning sound is working, and the interior light also turns on).
I'm still having problems with the passenger-side door.
The door light on the passenger-side door still isn't working when I open it. ;(
2. If I unlock the doors and open the passenger door, the alarm system no longer activates after about 30 seconds (which it always did before the microswitch replacement). Now, after about 30 seconds, the car locks the doors again (is this normal).
The car doesn't lock when I do the same thing on the driver's door (basically, unlocking, opening, and waiting). It only locks when I leave the doors closed.
Please help if you can!
Greetings, Babapapa.
