2.0 TDI starts and then immediately shuts down....
Falge86
Post26-01-2017, 14:04    Subject: 2.0 TDI starts and then immediately shuts down.... Quote
Hello everyone,
Unfortunately, I couldn't find anything useful through the search. Unfortunately
Here are the latest vehicle data:
Touran 2.0l TDI
Built in 2010
140 PS
~133000km
Now, regarding my problem.
It all started about 2 months ago. Vehicle was parked overnight, started successfully, but immediately shut off after about 2-3 seconds.
I restarted it again, and everything was normal. There was no performance loss or excessive smoking.
Currently, the problem has worsened. Must start it approximately 10-20 times before it starts running. icon_sad.gif
Then, I took the car to an independent garage that read the fault codes. Here, it was discovered that the DPF differential pressure sensor was defective.
Otherwise, there were no errors in the engine control unit.
The sensor has now been replaced. However, the problem still persists. Please close the pre-heating system. Immer wieder, the key fob malfunction is identified as the root cause of the problem.
The funny thing is, once he starts running, you don't have to worry about anything for the rest of the day.
Hoping someone can help me.
Thank you in advance.
2.0 TDI starts and then immediately shuts down.... - Startproblem.mp4
 File size:  887.23 KB
 Viewed:  11374 times
Post26-01-2017, 16:38    Subject: 2.0 TDI starts and then immediately shuts down.... Quote
Can the maximum speed be reached and maintained?
I suspect there is air in the fuel system. I will perform a pressure drop test on the auxiliary pump and look for any leaks in the fuel lines, filter, etc.
Best regards, Rainer
Wirus
Post27-01-2017, 8:36    Subject: 2.0 TDI starts and then immediately shuts down.... Quote
Please close the greenhouse. Immobilizer failure of 99%
Try using the spare key anyway to see if the same behavior occurs. It is possible that the transponder in your key is damaged.
Post27-01-2017, 18:10    Subject: 2.0 TDI starts and then immediately shuts down.... Quote
a) Is it a PD or a CR engine? Both are possible depending on the year of manufacture and the performance.
b) please perform an auto-scan.
Spaxs
2007 Skoda Octavia
Post13-05-2017, 20:21    Subject: 2.0 TDI starts and then immediately shuts down.... Quote
I've experienced something similar with a VW before. The 10A brake light fuse was defective. It sounds ridiculous, but that's exactly what happened. Also, a faulty brake light switch could also be the cause. When it comes to this, VW Group cars are definitely leading the way.
"Er war ein Mann, nicht mehr und nicht weniger. Nichts kann Ihn je ersetzen." - Lt. Cmd. Data als Hamlet in Star Trek
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. VW Golf TDI starts, then dies Diesel Engine Technology
No new posts Engine won't start, stalls at traffic lights Diesel Engine Technology
No new posts Seat Ibiza ASZ TDI: Starts, then dies Diesel Engine Technology
No new posts Engine Stalling: Troubleshooting & Fixes Diesel Engine Technology
