10 Cent Tuning, the same as...?
mfg!
Post25-01-2003, 4:07    Subject: 10 Cent Tuning, the same as...? Quote
Hello
A friend of mine recently bought an A3 TDI. According to the previous owner, the fuel injection pump was removed and the potentiometer was adjusted.
Now, in effect, it's the same as 10 cent tuning? It doesn't rust strongly, has an original 90 hp engine, and now, according to the dyno, has 118 hp.
Now what exactly was messed up (potentiometer) ??
Perhaps you could also assist us.
Best regards!
Post25-01-2003, 12:10    Subject: Re: 10 Cent Tuning, the same as...? Quote
Now, what exactly was messed up (potentiometer) ??
"If there is a pump with HDK sensor, then such an increase would not be possible without a flashing indicator light and/or severe jerking in the partial load range --> Technical article on RWG."
I don't know how the older type of power connectors (round instead of oval, 7-pin connectors) work.
mfg!
Post25-01-2003, 20:15    Subject: 10 Cent Tuning, the same as...? Translating...
[Translating...]Hi
Nun die Vorglühlampe blinkt eben nicht. Leichtes ruckel nur im unteren Bereich bei ca 1000-1500 U/min ( kaum spürbar man muß es wissen dann fällt es gering auf ).
Tja und vom alter es ist ein Bj 97 haben die alte Potigeberpumpen denke nicht oder ???
mfg Dankt
Post25-01-2003, 22:40    Subject: 10 Cent Tuning, the same as...? Translating...
[Translating...]
97er haben AFAIK auf jeden Fall die HDK-Pumpe.
118 PS glaube ich nicht. Da wird wohl die Messung gewaltig dazugelogen haben, und vermutlich war der Motor schon ab Werk recht kräftig.
Z.B. von 98 auf bestenfalls 110 PS, OK . . .
No new posts 10Cent Tuning Technical Articles
No new posts Tuning: Pay attention to intake manifolds and intercooling Technical Articles
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts 10 Cent Tuning Diesel Engine Technology
No new posts 10 Cent Tuning T4 2,5 75kW Diesel Engine Technology
No new posts 10 Cent Tuning warum Pin 2 und 3 ?????? Diesel Engine Technology
No new posts Diodes 20 cent tuning Diesel Engine Technology
