Hello fellow mechanics,
I have a Golf III TDI/GTI with an AFN engine. Now that the target value table is available online, I used VAGcom to measure the values for my engine. I noticed that at idle, in block 0, field 10, the air mass is 140 (target: 69..135), and in block 3, field 2 and 3, there is a huge difference between the target and actual values. Target (field 2): 285, Actual (field 3): 480.
Since I've owned the car (4 months), the error code 0575, 'regulation difference,' has appeared occasionally. It usually happens when the engine is cold.
My question:
Does that indicate a defective mass airflow sensor?
