Funding start 1z 1552
Bandit1200SA
Post20-07-2009, 20:39    Subject: Funding start 1z 1552 Quote
Hello, I'm new here.
First of all, thank you to the AMAZING FORUM here. I have already been able to save many double-mark deals thanks to you. icon_biggrin.gif
I have a problem: I have model 1552 and I want to set the Dynamic FB with it, but I don't have a manual.
Can anyone help me? I have already searched, but I haven't found anything.
What encoding should I enter?
Also noch etwas: Beim Austausch des Zahnriemens muss das O (die Abdeckung) am Getriebe bei OT (Outer Timing) halb verdeckt sein. Ist das richtig? Schaltgetriebe.
Car Rust, Consumes a lot, Does not rev above 4100 RPM in 5th gear.
Weakens under load and on inclines, extreme difficulty starting.
LLK cleaned and inspected. LMM replaced. Valve or relay for the charging pressure regulation replaced.
New vacuum hoses. New light bulbs.
New nozzles. Needle drivers.
No fault detected in the control unit. Starts up smoothly.
It idles between 1700 and 2200 RPM. Fuel lines checked. OK
700 km with almost 60 L seems like a very high consumption.
Timing belt replaced. FB not set.
The "O" next to "OT" wasn't completely missing before the gearbox bell.
Hoping this wasn't too much and placed in the right spot. icon_idea.gif Will avoid falling into the trap. icon_idea.gif
Thank you in advance. Sebastian.
Karma: +1333 / -0   Thank you, like it!
Post28-07-2009, 9:24    Subject: Funding start 1z 1552 Translating...
[Translating...]
die Reparatur- und Einstellanleitungen kannst Du für Deinen Audi hier online ordern:
https://erwin.audi.com/erwin/showHome.do
Eine Codierung ist nur erforderlich, wenn ein STG ersetzt wird. Details dazu in den Reparturanleitungen.
Der 1Z Motor mit Schaltgetriebe steht auf OT, wenn die "0" vor der Bezugskante am Getriebegehäuse steht.
No new posts VAG 1551 oder 1552?? Diesel Engine Technology
No new posts VAG 1552 1551 Volvo V70II 2.5 TDI D5252T? On-Board Diagnostics (OBD)
No new posts VAG 1552 K-line not switching to positive On-Board Diagnostics (OBD)
No new posts Start of ESP funding Diesel Engine Technology
