VP37: Troubleshooting Internal Housing Issues
wolle
Post28-07-2009, 21:31    Subject: VP37: Troubleshooting Internal Housing Issues Quote
Good evening, everyone.
Unfortunately, the search function did not provide me with an answer.
On my VP37, one of the axles has become slightly embedded in the housing near the roller ring. It's enough to affect the movement of the injection adjuster.
In the other axes, it is also sometimes noticeable, but only to a small extent that it is unlikely to have any impact.
Is there a way to get this working again using readily available materials?
My thought was, and still is, to use progressively finer sandpaper, up to approximately 2000 grit wet sandpaper, to carefully sand down a soft form in the area of the affected spot... In such a way that it no longer obstructs the axis of the roller.
Does anyone have a better suggestion, or can I actually do it this way?
Does anyone happen to have a working housing with a matching, also working, wing cell pump from an Audi A6, 140 hp, engine code AEL, "lying around"?
Thank you for your efforts, and I wish you a pleasant evening.
Wool.
Translated on 11-10-2026, 21:43.
tdi on water
Post29-07-2009, 6:49    Subject: VP37 Enclosure Issue: Troubleshooting Guide Quote
wolle wrote:
... Or does anyone by chance have a working housing with a matching, also working, wing impeller pump from an Audi A6, 140 hp, engine code AEL, "lying around"?
Wool
Hello Wolle,
I also have a pump and various engine parts for the 5-cylinder engine "lying around."
Ideally, send me a short private message with a phone number where I can reach you.
I'll get in touch with you later.
tdi on water
Translated on 11-10-2026, 21:45.
wolle
Post30-07-2009, 9:26    Subject: VP37: Troubleshooting Internal Housing Issues Quote
Good morning.
Okay.
@TDI on Water
You have a private message.
Even though the following might read well at first glance...
Please give me a call sometime... It would be really nice.
Regarding the issue:
I simply used a Dremel tool and a bit of patience to modify the sharp edges where the axles of the rollers were likely getting stuck, creating very smooth transitions.
After that, the pump was thoroughly cleaned of any foreign particles using a large amount of brake cleaner and compressed air, and then reassembled.
It's running smoothly again. Even the slight hesitation below 1400 RPM is gone now.
Previously, it was always noticeable, no matter how I adjusted the MSW on the pump.
So far, everything is okay.
Wool.
P.S.
I took some photos and recorded some measurements. I'll write a short report in the coming days.
Translated on 11-10-2026, 21:47.
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Repair of a VP37 manifold Troubleshooting & Guides
No new posts Function and components of an air conditioning system Technical Articles
This topic is locked, you cannot edit or reply. Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine... Diesel Engine Technology
No new posts VP37 Issue: AFN in T3 Van On-Board Diagnostics (OBD)
No new posts Fuel Injector Problem: AFN 99" VP37 Pump Diesel Engine Technology
No new posts Issue with starting the spray gun, model VP37 Diesel Engine Technology
