guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2403 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
23-06-2009, 15:46 Subject: 3C: AHK Retrofit, Bus Idle Issues |
I retrofitted a tow hitch to my Passat 3C and installed an aftermarket wiring kit. Sure, here is the translation of the text from German to English:
"This should be from Bosal."
Now I have several errors stored in the error memory.
Okay, bitte gib mir den deutschen Text, den du ĂŒbersetzt haben möchtest.
***EDIT: I'm going to cut this short here: I initially thought there might be a software update from VW for this, but that doesn't apply to my vehicle. Thank you to vagtuning.
"Does anyone know of similar issues with other vehicles, or perhaps even a solution to this problem?" I'm concerned that constant communication problems might prevent the CAN bus from settling down, which could lead to the battery being drained.
"Error code log attached (VIN removed to avoid directly criticizing the dealer). Communication problems occur every time a key is removed from the ignition. The trailer hitch lighting functions perfectly, both with and without the ignition on." AHK-related errors occur in the body control module (BCM), comfort control module (CCM), gateway control module (GCM), and AHK control module.
Guste.
Code: | Donnerstag,04,Juni,2009,17:16:58:49705
VCDS Version: RKS 805.2
Datenstand: 20090313
Fahrzeugtyp: 3C0
Scan: 01 02 03 04 08 09 15 16 17 18 19 25 37 42 44 46 47 52 53 55
56 62 69 72 77
Fahrzeug-Ident.-Nr.: WVWZZZ3CZ8E006xxx
01-Motor -- Status: OK 0000
02-Getriebe -- Status: OK 0000
03-Bremsen -- Status: OK 0000
04-Lenkwinkelsensor -- Status: OK 0000
08-Klima/Heizung -- Status: OK 0000
09-Bordnetz -- Status: Fehler 0010
15-Airbag -- Status: OK 0000
16-Lenkrad -- Status: OK 0000
17-Kombiinstrument -- Status: OK 0000
18-Standheizung -- Status: Fehler 0010
19-CAN-Gateway -- Status: Fehler 0010
25-Wegfahrsperre -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-TĂŒrelektr. Fahrer -- Status: OK 0000
44-Lenkhilfe -- Status: OK 0000
46-Komfortsystem -- Status: Fehler 0010
47-Soundsystem -- Status: OK 0000
52-TĂŒrelektr. Beifahr. -- Status: OK 0000
53-Feststellbremse -- Status: OK 0000
55-Leuchtweitenreg. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-TĂŒrelektr. hi. li. -- Status: Sporadischer Kommunikationsfehler 1000
69-AnhÀnger -- Status: Sporadischer Kommunikationsfehler 1000
72-TĂŒrelektr. hi. re. -- Status: OK 0000
77-Telefon -- Status: OK 0000
Adresse 01: Motor Labeldatei: RKS\03G-906-021-BMM.lbl
Teilenummer SW: 03G 906 021 NK HW: 03G 906 021 AB
Bauteil: R4 2,0L EDC G000AG 9971
Revision: --H07--- Seriennummer: VWZCZ000000000
Codierung: 0000078
Betriebsnr.: WSC 48992 143 80611
Kein(e) Fehler gefunden.
Readiness: 0 0 0 0 0
Adresse 02: Getriebe Labeldatei: RKS\02E-300-0xx.lbl
Teilenummer SW: 02E 300 051 HW: 02E 927 770 AJ
Bauteil: GSG DSG AG6 431 1817
Revision: 04843012 Seriennummer: 00000809080793
Codierung: 0000020
Betriebsnr.: WSC 04926 001 00001
Adresse 03: Bremsen Labeldatei: Keine
Teilenummer SW: 3C0 614 109 D HW: 3C0 614 109 D
Bauteil: J104 C4 440 V2 0003
Revision: --020--- Seriennummer: 00000775427338
Codierung: 0000270
Betriebsnr.: WSC 05311 000 00000
Adresse 08: Klima/Heizung Labeldatei: RKS\3C0-907-044.lbl
Teilenummer SW: 3C0 907 044 CD HW: 3C0 907 044 CD
Bauteil: ClimatronicPQ46 122 0708
Revision: 00122021 Seriennummer: 00000000000000
Adresse 09: Bordnetz Labeldatei: RKS\3C0-937-049-30-H.lbl
Teilenummer SW: 3C0 937 049 AL HW: 3C0 937 049 AL
Bauteil: Bordnetz-SG H54 2202
Revision: 00H54000 Seriennummer: 01000007013612
Codierung: E38A8F6701281A00470A00000F000000000F5D435C400100000000000000
Betriebsnr.: WSC 05124 000 00000
Teilenummer: 3C1 955 419 A
Bauteil: Wischer 020507 003 0205
Codierung: 00046997
Teilenummer: 1K0 955 559 AB
Bauteil: RLS 210507 020 0105
Codierung: 00479269
2 Fehler gefunden:
01333 - TĂŒrsteuergerĂ€t hinten links (J388)
004 - kein Signal/Kommunikation - Sporadisch
Umgebungsbedingungen:
Fehlerstatus: 00100100
FehlerprioritÀt: 2
FehlerhÀufigkeit: 1
VerlernzÀhler: 19
Kilometerstand: 111832 km
Zeitangabe: 0
Datum: 2009.05.14
Zeit: 17:27:00
aus
Spannung: 12.40 V
aus
ein
aus
aus
aus
01517 - SteuergerĂ€t fĂŒr AnhĂ€ngererkennung (J345)
FehlerprioritÀt: 2
FehlerhÀufigkeit: 254
VerlernzÀhler: 40
Kilometerstand: 111024 km
Zeitangabe: 0
Datum: 2009.04.20
Zeit: 14:05:00
aus
Spannung: 12.35 V
aus
ein
aus
aus
aus
Adresse 15: Airbag Labeldatei: RKS\3C0-909-605.lbl
Teilenummer SW: 3C0 909 605 N HW: 3C0 909 605 N
Bauteil: 19 AIRBAG VW8R 032 2522
Revision: 13032000 Seriennummer: 003B2P9SJP3$
Codierung: 0012601
Adresse 16: Lenkrad Labeldatei: RKS\3C0-953-549.lbl
Teilenummer SW: 3C0 953 549 K HW: 3C0 953 549 K
Bauteil: J0527 0015
Revision: 00006000 Seriennummer: 3C9953507BG
Codierung: 0001112
Teilenummer: XXXXXXXXXXX
Bauteil: E0221 002 0010
Adresse 17: Kombiinstrument Labeldatei: RKS\3C0-920-xxx-17.lbl
Teilenummer SW: 3C0 920 871 E HW: 3C0 920 871 E
Bauteil: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Seriennummer: 00000000000000
Codierung: 0007105
Betriebsnr.: WSC 48992 141 87099
Adresse 18: Standheizung Labeldatei: RKS\1K0-815-007.lbl
Teilenummer: 1K0 815 007 BH
Bauteil: Standheizer 042 4404
Revision: 00042000 Seriennummer: 09011075000000
Codierung: 0000012
1 Fehler gefunden:
01407 - Flammenabbruch
000 - - - Sporadisch
Fehlerstatus: 00100000
FehlerprioritÀt: 3
FehlerhÀufigkeit: 1
VerlernzÀhler: 29
Kilometerstand: 112028 km
Zeitangabe: 0
Datum: 2009.05.25
Zeit: 07:13:12
Start
Temperatur: 80.0°C
Temperatur: 78.0°C
Spannung: 14.45 V
Adresse 19: CAN-Gateway Labeldatei: 3C0-907-530.lbl
Teilenummer SW: 3C0 907 530 E HW: 3C0 907 951
Bauteil: J533__Gateway H10 0080
Revision: H10 Seriennummer: 1200P0752206E2
Codierung: FD817F46500E022002
2 Fehler gefunden:
FehlerprioritÀt: 2
FehlerhÀufigkeit: 216
VerlernzÀhler: 40
Zeitangabe: 0
Datum: 2009.04.20
Zeit: 14:05:22
FehlerprioritÀt: 2
FehlerhÀufigkeit: 1
VerlernzÀhler: 18
Zeitangabe: 0
Datum: 2009.05.14
Zeit: 17:27:29
Adresse 25: Wegfahrsperre Labeldatei: RKS\3C0-959-433-25.lbl
Teilenummer SW: 3C0 959 433 R HW: 3C0 959 433 R
Bauteil: IMMO 042 0383
Revision: 00042000 Seriennummer: VWZCZ000000000
Betriebsnr.: WSC 131071 1023 2097151
Teilenummer: 3C0 905 861 G
Bauteil: ELV 027 0380
3C0905861G ELV 027 0380
Adresse 37: Navigation Labeldatei: RKS\1K0-919-887-MFD2.lbl
Teilenummer: 1K0 919 887 F
Bauteil: Navigation 0030
Codierung: 0000101
Betriebsnr.: WSC 05314 000 00000
Adresse 42: TĂŒrelektr. Fahrer Labeldatei: RKS\1K0-959-701-MIN3.lbl
Teilenummer SW: 1K0 959 701 P HW: 1K0 959 793 L
Bauteil: J386 TUER-SG FT 1131
Revision: 32008001 Seriennummer: 00000025278510
Codierung: 0000181
Adresse 44: Lenkhilfe Labeldatei: RKS\1Kx-909-14x.lbl
Teilenummer: 1K1 909 144 M
Bauteil: EPS_ZFLS Kl.135 H08 1901
Betriebsnr.: WSC 02069 000 90108
Adresse 46: Komfortsystem Labeldatei: RKS\3C0-959-433-46.clb
Bauteil: KSG PQ46 ELV 042 0472
Codierung: 0091020051034E7630001415700C4F0E507840
Teilenummer: 1K0 951 605 C
Bauteil: LIN BACKUP HORN H03 1301
Bauteil: NGS n.mounted
Bauteil: IRUE n.mounted
1 Fehler gefunden:
FehlerprioritÀt: 4
VerlernzÀhler: 40
Zeitangabe: 0
Datum: 2009.04.20
Zeit: 14:05:20
Adresse 47: Soundsystem Labeldatei: RKS\3C0-035-456.lbl
Teilenummer: 3C0 035 456 D
Bauteil: 08K Audioverst. 0005
Revision: 00002000 Seriennummer: 00000004106284
Adresse 52: TĂŒrelektr. Beifahr. Labeldatei: RKS\1K0-959-702-MIN3.lbl
Teilenummer SW: 1K0 959 702 P HW: 1K0 959 792 L
Bauteil: J387 TUER-SG BT 1131
Revision: 32008001 Seriennummer: 00000075278503
Codierung: 0000180
Adresse 53: Feststellbremse
nicht erreichbar
Adresse 55: Leuchtweitenreg. Labeldatei: RKS\5M0-907-357-A.lbl
Teilenummer SW: 5M0 907 357 A HW: 5M0 907 357 A
Bauteil: AFS-Steuergeraet X014
Revision: H01 Seriennummer:
Codierung: 2301953
Teilenummer: 7L6 941 329
Bauteil: AFS-Lst.-Modul l X018
Codierung: 00000035
Teilenummer: 7L6 941 330
Bauteil: AFS-Lst.-Modul r X018
Codierung: 00000035
Adresse 56: Radio Labeldatei: RKS\1K0-035-095.lbl
Teilenummer: 1K0 035 095 G
Bauteil: Radio 0030
Codierung: 0012042
Adresse 62: TĂŒrelektr. hi. li. Labeldatei: RKS\1K0-959-703-GEN3.lbl
Teilenummer SW: 1K0 959 703 P HW: 1K0 959 795 G
Bauteil: J388 TUER-SG HL 1119
Revision: 11006001 Seriennummer: 00000001728990
Codierung: 0000144
Adresse 69: AnhÀnger Labeldatei: Keine
Teilenummer SW: 30/ 1V2 .0 HW: 30/ 1V2 .0
Bauteil: ANHAENGER_MODULE UN 0030
Codierung: 0000001
5 Fehler gefunden:
02562 - Lampen fĂŒr Bremslicht am AnhĂ€nger
011 - Unterbrechung
02563 - Lampe fĂŒr Schlusslicht rechts am AnhĂ€nger (M61)
011 - Unterbrechung
02564 - Lampe fĂŒr Schlusslicht links am AnhĂ€nger (M60)
011 - Unterbrechung
02565 - Blinkleuchten rechts am AnhÀnger (M63)
011 - Unterbrechung
02566 - Blinkleuchten links am AnhÀnger (M62)
011 - Unterbrechung
Adresse 72: TĂŒrelektr. hi. re. Labeldatei: RKS\1K0-959-704-GEN3.lbl
Teilenummer SW: 1K0 959 704 P HW: 1K0 959 794 G
Bauteil: J389 TUER-SG HR 1119
Revision: 11006001 Seriennummer: 00000001734546
Codierung: 0000144
Adresse 77: Telefon Labeldatei: RKS\3C0-035-729.lbl
Teilenummer SW: 3C0 035 729 G HW: 3C0 035 729 G
Bauteil: Telefon 7609
Revision: 00012000 Seriennummer: 0000000912806
Codierung: 0016041
Profile PM Garage |
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
23-06-2009, 18:21 Subject: 3C: AHK Retrofit, Bus Idle Issues |
Quote: | | It is incomprehensible to me why a mandatory AHK test is required for a software update of a gateway control unit (which was already installed in the car before the AHK was added). |
Is there another TPL available for the gateway? Perhaps there will be an update available even for cars without a trailer hitch, in which case it would be difficult to perform an AHK function test, wouldn't it?
Once the latest software is installed, it doesn't matter to you whether the reason for the update was a bug in the AHK or something else.
Profile PM WWW Garage |
vagtuning Guest
24-06-2009, 17:28 Subject: 3C: AHK Retrofit, Bus Idle Issues |
Your GW cannot be updated further, as the TPI only supports vehicle-related data.
with a gateway up to a maximum of... Index C applies, but you have installed Index E!
25-06-2009, 0:28 Subject: 3C: AHK Retrofit, Bus Idle Issues |
vagtuning wrote: | Your GW cannot be further updated, as the TPI is only for vehicles.
with a gateway up to a maximum of... Index C applies - and you have installed Index E! |
Oh my.
You're welcome!
Although I had paid very close attention to the index, I hadn't noticed the leading three digits, so "xxx 907 530 E" becomes "xxx 907 530 K". I hadn't noticed that the first list only included 1K0 control units, while the 3C0 control units are listed further down, and, as you correctly pointed out, only up to index C.
Therefore, the question of whether Volkswagen will release a GW update is no longer relevant.
There's only one thing left to consider: what else can I do?
I've recently learned from an acquaintance who installed a Westfalia electric drive kit on their Touran (manufactured in 2009), and it seems to be exhibiting the same error messages in the same control units. This is particularly surprising, considering that Westfalia is supposedly the company that manufactures the VW control units. Some forums even report that, underneath the Westfalia retrofit sticker, there was a VW sticker.
Guste.
Profile PM Garage |
25-06-2009, 8:44 Subject: 3C: AHK Retrofit, Bus Idle Issues |
Hi.
I'm having trouble with my...
Code: |
Teilenummer SW: 3C0 907 530 C HW: 3C0 907 951 A
Bauteil: Gateway 007 0040
Revision: 00007000 Seriennummer: 0700C06C180274
Codierung: 7DFD0C14C62002
Problems when I look at the org. AHK, are you listening?
Profile PM Garage |
25-06-2009, 10:30 Subject: 3C: AHK Retrofit, Bus Idle Issues |
I'm dealing with my problems when I look at the org. AHK, are you ready?
Yep, a dead battery due to a lack of bus tranquility. Drive to VW and have the software updated from version 40 to 48 according to the TPL (Technical Product Lifecycle) guidelines.
I'll send you an email with more details shortly.
Hendrik.
Profile PM Garage |
ruebasan
15-08-2009, 17:29 Subject: Re: 3C: Retrofitting AHK, Bus Ruhe Problems |
Hello guste100,
I'm having the same problem!
The trailer hitch with control unit and cut wiring harness.
I bought these parts from a car dismantler; they are supposed to be in a...
Passat 3C model. The tow hitch is made by Westfalia.
Here's a section of the log from my Passat:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genieĂen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 3C0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72
Vehicle Identification Number: WVWZZZ3CZ7Exxxxxx
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Main Electrical System -- Status: Error 0010.
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnostic interface -- Status: Error 0010.
Immobilizer -- Status: OK 0000
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: Error 0010.
52-door electric. Front passenger seat. -- Status: OK 0000.
53-Parking brake -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000.
69 followers -- Status: Intermittent communication error 1000.
72-Door, electric, high, right side -- Status: OK 0000.
"Der schnelle braune Fuchs springt ĂŒber den faulen Hund."
Address 09: Central Electronics
Label file: DRV\3C0-937-049-30-H.lbl
Part number SW: 3C8 937 049 E Hardware number: 3C8 937 049 E
Component: On-board network module H54 2602.
Revision: 00H54000 Serial Number: 00000005798099
Encoding: 008C8F0700041000400A00000F000000000959435C000000000000000000
Operating Number: WSC 00000 000 00000
Part number: 3C1 955 419 A
Part: Wiper 130307 003 0205
Encoding: 00046997
"1 error found:"
01517 - Trailer detection control unit (J345)
004 - No signal/communication - Sporadically.
Environmental conditions:
Error status: 00100100
Error priority: 6
Error frequency: 254
Lost Count: 130
Mileage: 15,090 km
Time: 0
text
from
Voltage: 11.75 V
text
from
one
text
from
text
from
text
from
Address 19: Diagnostic interface
Label file: 3C0-907-530.lbl
Part number SW: 3C0 907 530 C, HW: 3C0 907 951 A.
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C07413036E
Encoding: 3DFD8C04C22002
Operating number: WSC 05311 000 00000
"1 error found:"
Error priority: 2
Error frequency: 150.
Lost Count: 130
Mileage: 15,090 km
Time: 0
Date: 2000.00.00
Time: 19:39:32
Address 46: Comfort System Label file: DRV\3C0-959-433-46.clb
Part number SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: KSG PQ46 ELV 042 0472
Revision: 00042000 Serial Number: VWZCZ000000000
Encoding: 0091020051030E763004941570084F0B607CA0
Component: Sounder, not mounted.
Component: NGS, not mounted.
Component: IRUE, not mounted.
"1 error found:"
Error priority: 4
Error frequency: 153.
Lost Count: 130
Mileage: 15,090 km
Time: 0
Date: 2000.00.00
Time: 19:39:29
Address 69: Trailer (J345) Label file: DRV\1K0-907-383-MY7.lbl
Part number SW: 1K0 907 383 B, Hardware number: 1K0 907 383 B.
Part: Trailer H13 0050
Revision: 2A000000 Serial number: 00005500000532
Encoding: 0100000200000000
Operating number: WSC 00028 028 00001
No error codes found.
Last month, the car was at VW for its inspection, but...
It also didn't make any difference.
I found a note in an installation manual for an Audi on the internet:
Regarding the "no signal/communication - sporadic" message.
read "you should simply ignore this notice."
I don't see that as a solution!
ruebasan
15-08-2009, 21:39 Subject: 3C: AHK Retrofit, Bus Idle Issues |
Hello Ruebesan,
At least you have an original VW trailer hitch control unit. Your gateway is also up to date.
This is a real problem that Volkswagen should really try to solve. Unfortunately, I suspect that VW will point out that the AHK control unit is not the latest version (the current version is index E, not B) and that they will try to replace the AHK control unit.
It would be interesting to know if it would be better then. But are you sure you want to take on those costs without any guarantee?
Short question: Have you checked if the DWA (door/window alarm) is working for you? I haven't noticed any malfunctions on my end. Recently, I wanted to test if the alarm system (as described in the manual) works when the DWA is connected. According to the manual, the alarm system should trigger if the DWA is activated and then the plug is pulled. Unfortunately, I haven't been able to achieve that yet, even though all the lights on the caravan are correctly wired and functioning.
Perhaps the DWA function is the one that doesn't work in the older STGs and some retrofitted AHK-STGs. It would be interesting to know if this feature was already available on the first 3C models from 2005, or if it was implemented later.
Guste.
Profile PM Garage |
vagtuning Guest
15-08-2009, 21:51 Subject: 3C: AHK Retrofit, Bus Idle Issues |
I still have some Index D plus internal wiring harnesses available.
Only the wiring harness to the connector is missing.
| Description: |
| File size: |
710.48 KB |
| Viewed: |
12882 times |
15-08-2009, 21:58 Subject: 3C: AHK Retrofit, Bus Idle Issues |
Do you happen to know if the errors listed above occurred with that?
What would you like in return?
Profile PM Garage |
vagtuning Guest
15-08-2009, 22:03 Subject: 3C: AHK Retrofit, Bus Idle Issues |
I don't have precise answers to either the first or the second question.
Opinions or beliefs, but the latter doesn't really belong here either.
It was mainly intended to be informative; if you need anything, just reach out via private message.
16-08-2009, 0:02 Subject: 3C: AHK Retrofit, Bus Idle Issues |
My Index E surprisingly doesn't have any problems with the C CAN-GW using software 0040, even though there's a TPL associated with it.
Perhaps Guste can test drive the D sometime  . Thanks to the second battery, you can quickly access the connectors, right?
Profile PM Garage |
16-08-2009, 8:44 Subject: 3C: AHK Retrofit, Bus Idle Issues |
dieselmartin wrote: | Maybe guste can test drive the D sometime . Thanks to the second battery, you can quickly access the connectors, right? |
That's a great idea!
But (aside from the fact that I don't know if vagtuning would even lend out the control unit), my aftermarket Bosal E-kit unfortunately has completely different connectors (or only one instead of two), so while I can easily access it, I can't simply swap them around.
Otherwise, I probably would have jumped in without further questioning.
But I'm curious to see if Ruebesan wants to take the test, and if so, whether it could then be narrowed down to the AHK-STG group.
Guste.
Profile PM Garage |
ruebasan
16-08-2009, 13:44 Subject: 3C: AHK Retrofit, Bus Idle Issues |
I also hoped that during the inspection at VW, they would find a...
new software for the trailer hitch control unit.
Unfortunately, that didn't happen.
I would try swapping the test with the control unit.
already carry out...
ruebasan
