VW Passat 3B6 2.0 TDI (BGW) measurement blocks
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
ormowiec
Karma: +0 / -1   Thank you, like it!
Post09-09-2009, 14:15    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
"First, I apologize for writing in English - my knowledge of German is very poor (passing the anti-spam questions was really difficult icon_biggrin.gif)."
I am looking for standard values for engine measuring blocks. Engine code BGW, VW Passat Variant 2.0 TDI, 2004 with DPF. I suspect the PD injectors are failing (BIP values in the 023 range are up to 40).
ORMO
Translated on 15-07-2026, 0:57.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post09-09-2009, 20:25    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
Standard values for the engine measurement module (MWB) 23 =
-100 to +100
Passat Variant BGW 2005
Translated on 15-07-2026, 0:58.
Karma: +796 / -0   Thank you, like it!
Post09-09-2009, 21:43    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
Just check your VCDS label file...
ormowiec
Post10-09-2009, 9:37    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
Hi.
Sure, you're welcome.
Just look in your VCDS label file...
I have VCDS versions 805.4-PL and 908-EN, and there is no label file available for this engine icon_sad.gif.
Standard values for engine control unit (ECU) data block MWB 23 =
-100 to +100
Well, in fact, I was looking for this block vals icon_smile.gif, thank you very much. Are you sure that the BIP (Bosch Injection Pump) has such a large range in this engine? As far as I know, for typical TDI-PD engines, it's usually around +/- 30.
[Edit Admin: I think there is absolutely no need to link to some file hosters as the attachment function in this forum is inteded for this purpose.Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
ORMO
Please provide the text you would like me to translate from German to English.
one more question.
004.4 = camshaft/crankshaft synchronization, similar to that found in the 1.9 TDI-PD engine?
Translated on 15-07-2026, 1:00.
Steffen W
Post10-09-2009, 21:16    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
The name of the label file is 038-906-016-BGW.lbl, and it's located in the "labels" directory.
Yes, and I'm certain, from +100 to -100.
Translated on 15-07-2026, 1:02.
ormowiec
Post11-09-2009, 8:46    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
Okay, I'm sure there isn't a file with that name in my VCDS labels. There's nothing listed with "*BGW*".
And yes,iam sure +100 to -100.
Thank you very much icon_biggrin.gif.
Translated on 15-07-2026, 1:03.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts Doku Passat MKB AVB, Kraftstoffverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B: Kat vom 110 PS TDI an den 115 PS PD TDI? Diesel Engine Technology
No new posts MFL Passat 3BG Electrical Systems, Vehicle Electronics, Multimedia
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat 3C cornering light Transmission, Chassis, Body & Interior
