Georg_G Profi-Schrauber
Joined: 04/12/2002 Posts: 332 Karma: +6 / -0 Location: Freiburg im Breisgau 2012 Volkswagen Golf Support
21-04-2010, 18:41 Subject: ESD Spacer Washers: Secure & Protect |
Hello forum,
I made a mess while disassembling the dust stoppers from an AEL.
The conical washer, which the retaining bolt presses against the retaining bracket, has fallen into the engine compartment, into a really difficult-to-reach spot.
Does anyone know if:
*) This washer can be purchased individually.
*) I could just use a regular (flat) washer. Probably not, though, right? Or does anyone know otherwise?
Best regards, Georg. Golf VI Variant (2012) 140 tkm, CFHC Schummeldiesel
Translated on 06-10-2026, 4:53.
Profile PM Garage |
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
21-04-2010, 18:51 Subject: ESD Spacer Washers: Secure & Protect |
I used two standard flat washers.
It has fulfilled its purpose until today  . Kaum macht man es richtig, funktioniert es!
Translated on 06-10-2026, 4:54.
Profile PM Garage |
21-04-2010, 21:09 Subject: ESD Spacer Washers: Secure & Protect |
Hi Klahaui,
Brave, brave. Isn't the conical washer important to ensure correct alignment of the nozzle holder? After all, the screw sits centered in the retaining bracket due to the conical shape.
But your good experience gives me hope  .
Does anyone know the part number for something like that?
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2403 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
21-04-2010, 21:35 Subject: ESD Spacer Washers: Secure & Protect |
Georg_G wrote: | | Does anyone know the part number for something like that? |
N 023 731 4, Target disc, 8.4mm, €0.50.
Translated on 06-10-2026, 4:55.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18115 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
22-04-2010, 8:12 Subject: ESD Spacer Washers: Secure & Protect |
...or as a "quick fix," use two regular washers with a screw and nut inserted into the drill, and then bend/file them into a conical shape.
Translated on 06-10-2026, 4:56.
Profile PM WWW Garage |
22-04-2010, 20:26 Subject: ESD Spacer Washers: Secure & Protect |
@Guste100:
Thank you for the spare part number. It will probably be very helpful to me.
I assume that's a VAG replacement part number? Or from Bosch? Well, it will probably be easy to clarify tomorrow with a phone call  .
@Rainer:
It's also a good idea, but I'm not in a huge hurry. The car (a Volvo 850 TDI with already 300,000 km on the odometer) is just sitting there for now while the injectors are being replaced. That will take a few more days.
Translated on 06-10-2026, 4:57.
Profile PM Garage |
Wiesel Profi-Schrauber
Joined: 04/06/2008 Posts: 896 Karma: +43 / -0 Location: Schleswig-Holstein
22-04-2010, 20:45 Subject: ESD Spacer Washers: Secure & Protect |
Hello Georg,
That is a VAG number.
Micha Touran 5T1 / DFGA / TGV; Fabia 6Y5 / BNV / GGV
Translated on 06-10-2026, 4:58.
