Audi/VW Steuergerät Vergleich: Find the Best!
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post22-09-2009, 18:12    Subject: Audi/VW Steuergerät Vergleich: Find the Best! Quote
Since I suspect my control unit is broken, I have a question:
My engine control unit (ECU) has the part number 028 906 021 F. I might be able to get one to test and potentially keep, but it has the part number 028 906 021 B. What are the differences between these two ECUs?
Both are from the 1Z engine, but mine is from an Audi B5, and the one with "B" at the end is from a 1994 Passat 1Z. Mine is from the year 1995.
Are they the same, or what is the difference between them?
Is the difference significant enough that the other control unit wouldn't work?
Thank you and best regards.
Thilo.
EDIT: Which letters might still be usable at the end?
Translated on 20-10-2026, 5:03.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts A4 V6 2.5 TDI: Fuel Injector Comparison Diesel Engine Technology
No new posts ESP comparison > Poti and... HDK Sensors Diesel Engine Technology
No new posts Audi A4 Wiring Diagram: MSA 15.5 Controller Diesel Engine Technology
No new posts Audi A4 Immobilizer Control Unit On-Board Diagnostics (OBD)
