AEL Motor Login Code: Start Quantity Example
Pölscheich
Post23-09-2009, 19:18    Subject: AEL Motor Login Code: Start Quantity Example Quote
Hello.
I'd like to adjust the initial amount and feed start values in my AEL system (mainly to optimize the pellet production), but I can't access the control unit with the usual login "12233".
I've been searching the forum for a while now, and I've read multiple times that the login doesn't work for the 5-cylinder models, or that a different code is required.
Can anyone share the code for the AEL (presumably referring to an engine control unit or similar system), or suggest alternatives for making small adjustments to parameters like initial fuel quantity, start of injection, idle speed, or injection volume?
Sure, no problem.
Greetings.
Translated on 13-10-2026, 13:14.
Back to top Profile PM Email
Karma: +807 / -0   Thank you, like it!
Post23-09-2009, 20:58    Subject: AEL Motor Login Code: Start Quantity Example Quote
What is the VAG part number for the engine control unit?
Translated on 13-10-2026, 13:16.
Pölscheich
Post23-09-2009, 21:44    Subject: AEL Motor Login Code: Start Quantity Example Quote
Hello.
I've added an extra laptop and Auo again.
Tax device number is 4A0 907 401 P.
Sure, no problem.
Greetings.
Post24-09-2009, 11:45    Subject: AEL Motor Login Code: Start Quantity Example Quote
Ich kann den Inhalt dieser URL nicht abrufen, da ich keinen Zugriff auf das Internet habe. Bitte gib mir den Text, den du übersetzt haben möchtest.
Login 22158 seems to be correct...
Translated on 13-10-2026, 13:17.
Pölscheich
Post24-09-2009, 18:08    Subject: AEL Motor Login Code: Start Quantity Example Quote
Hello.
Just wanted to let you know that the login is working correctly!
You're welcome.
Greetings.
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ECU Login Code: How to Find & Use On-Board Diagnostics (OBD)
No new posts Login Code for Comfort Control Unit Diesel Engine Technology
This topic is locked, you cannot edit or reply. 7-Digit Login Code: Find & Generate Now On-Board Diagnostics (OBD)
No new posts Looking for login code for comfort control unit On-Board Diagnostics (OBD)
