Boost Gauge, Smell? - Troubleshooting Guide
VWGOLFIII
Post23-03-2003, 18:55    Subject: Boost Gauge, Smell? - Troubleshooting Guide Quote
Hello.
I installed a boost gauge in my Golf III TD, and I think that when the engine oil is at operating temperature (according to the gauge, 85-100°C) and I press the accelerator pedal so that the turbocharger generates boost, I can smell a slight odor of engine oil or even exhaust fumes. Has anyone else experienced this? Is there a way to install a filter or something similar to eliminate this smell from inside the car?
Otherwise, I don't smell anything in the car, only when the turbocharger is working, and then only when the engine is warm?
Thank you for the help icon_wink.gif icon_wink.gif.
Translated on 30-08-2026, 17:39.
Post23-03-2003, 22:06    Subject: Boost Gauge & Smell: Troubleshooting Guide Quote
VWGOLFIII wrote:
Otherwise, I don't smell anything in the car, only when the turbocharger is working, and then only when the engine is warm.
Hi.
Try activating the engine compartment indicator light using a syringe, like a doctor's syringe.
If you find that the pressure is slowly decreasing, you probably have a leak somewhere (happy searching icon_sad.gif), which will give you that smell... I would then plug it, rather than messing around with filters icon_wink.gif.
Translated on 30-08-2026, 17:41.
VWGOLFIII
Post25-03-2003, 15:59    Subject: Boost Gauge: Monitor Turbo Pressure & Performance Quote
Hello Ulf,
Thank you for the tip. I found and fixed the error.
Best, Mark.
Translated on 30-08-2026, 17:42.
Flip
Post26-03-2003, 7:29    Subject: Boost Gauge, Smell? - Troubleshooting Guide Quote
It would be interesting to know what it actually was.
No new posts Digital boost pressure indicator Troubleshooting & Guides
No new posts Boost Gauge: Essential for Every TDI Engine Troubleshooting & Guides
No new posts Occasional Smoke & Burning Smell: What to Do? Diesel Engine Technology
No new posts Boost Gauge: Display & Monitoring Diesel Engine Technology
No new posts Boost Gauge: Which One Is Right? Diesel Engine Technology
No new posts What boost gauge? Diesel Engine Technology
